Old 15-08-2006, 06:49 AM   #1 (permalink)
Default shaking display
my display shakes while using it
it is samtron monitor of samsung 15'' colour
plz help
or advice
rounit is offline
Old 15-08-2006, 10:45 AM   #2 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
Default Re: shaking display
Try to degauss the monitor and also try to change to other resolutions and refresh settings!
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 15-08-2006, 10:48 AM   #3 (permalink)
ayush_chh's Avatar
i had the same monitor and the same problem..........is ur monitor too old?........then its all because of the faulty pic tube......
eXPerience is what a MAN learn's fROM.....
ayush_chh is offline
Old 15-08-2006, 01:49 PM   #4 (permalink)
royal's Avatar
Question Re: shaking display
I am having the same problem with my 4 yrs old Samsung SyncMaster750s monitor...
How much did it cost to rectify the problem
royal is offline
Old 15-08-2006, 07:51 PM   #5 (permalink)
Keep speakers and power adapters far from the monitor. Try to increase the refresh rate.
Regards.
Homiyar.
homiyar is offline
Old 15-08-2006, 11:02 PM   #6 (permalink)
ayush_chh's Avatar
@ royal
sorry dude no repairing......i bought a new one.....
on 2nd thouts 'homiyar' may be correct.....if u keep ur UPS or Stablelizer near 2 ur monitor then some times due to voltage fluctuations the pic is affected...
Old 16-08-2006, 09:27 AM   #7 (permalink)
montylee's Avatar
I am facing the same problem with my Samsung Samtron 15 inch monitor (samtron 55v i guess)
The problem started appearing recently when i moved my TV near to my PC, so it is probably bcoz of the magnetic field.
Try to keep ur monitor away from any magnetic devices.
Intel Core 2 Duo E6300, Intel DG965RY, MSI 8600GT OC, WD 250GB SATA-II Harddisk, Transcend 1GB 667 Mhz DDR2 RAM, Samsung Samtron 55V, Sennheiser HD485 cans, Zebronics LAVA Cabinet, Zebronics 400W PSU
montylee is offline
Old 16-08-2006, 10:12 AM   #8 (permalink)
q3_abhi's Avatar
Try changing the refresh rates.
i think this shud solve the problem.
Fragging is the key to Success!!!!!
My blog : http://q3abhi.wordpress.com
q3_abhi is offline
Old 28-08-2006, 06:19 PM   #9 (permalink)
Keep Everything Away from Monittor Which have Speakers OR you know the product have magnet Inside.
Stick is offline
- by c4u
