Old 14-08-2006, 11:19 PM   #1 (permalink)
String Phreak
mediator's Avatar
Red face Hardisk not detected+BSODs!
Hi friends.....I've been experiencing some hardware problems these days.
Present Configuration
1. 160Gb WD HDD + 80 GB seagate hdd
2. 512 MB ram
3. 2.4 Ghz processor
3. Nvidia 5200 graphic card!
Problem :
1. Now whenever I am on the system........it sometimes shows "Kernel page error" and then the system hangs in Xp. When I reboot it shows System disk failure error!
The same is case with Fedora 5. It hangs and followed by same error.
2. Playing games like Quake 3 it shows all kind of blue screens!
Now because of the problem I changed the IDE connectors and CMOS battery. But still the error persists!
Also What will be the price for upgradation for
1. RAM : 1 GB
2. Processor Duo core : suggest
3. Motherboard : suggest
4. Cabinet : suggest
Suggest the best of kinds for above with their prices under Budget = 20 K (max).
Help!
mediator is offline
Old 14-08-2006, 11:33 PM   #2 (permalink)
In Pursuit of "Happyness"
kalpik's Avatar
Default Re: Hardisk not detected+BSODs!
99.9% its a faulty RAM module.
kalpik is online now
Old 15-08-2006, 12:24 AM   #3 (permalink)
String Phreak
mediator's Avatar
Thanx for reply.........but u sure?........I mean have u experienced it ? And what abt hardisk detection is it RAM based toooo?
mediator is offline
Old 22-08-2006, 11:33 PM   #4 (permalink)
String Phreak
mediator's Avatar
Hey....I observed when I put another fan inside...the BSODs reduced greatly!! Even mah bro's not complaining nowadays. Can it be a heating problem??
Neways can u suggest some good cheap cooling solutions??
mediator is offline
- by c4u
