Old 12-08-2006, 09:16 PM   #1 (permalink)
Stalker's Avatar
Unhappy RAM upgrade problem
hey guys, i hv an intel 845D AGP chipset on my comp. it has two slots for SD-RAM
now, here's the problem
i have 2 128 mb 133Mhz modules. i hv got my friends 256 mb 100Mhz module 4 some days. but when i try to put the 256 + 128 combination, the system detects it as 256 mb or sometimes refuses to boot up. i tried this with the other 128 module as well. 4 some reason the system does not detect the total RAM as 384. is this a memory timing mismatch??
Also where can i find out the maximum RAM capacity supported by my mobo??
will upgrading my BIOS help??
| C2Q Q6600 G0 | Intel DG33FB | 4 GB Corsair 6400C5G DDR2-800Mhz | XFX 8800GTX | CM Extremepower 600W | 250GB Seagate HDD | Lite-ON 1635S DVD RW | Logitech MX-518 | Zalman RS6F | APC RS 800 |
Stalker is offline
Old 12-08-2006, 09:55 PM   #2 (permalink)
Alive Again...
satyamy's Avatar
Default Re: RAM upgrade problem
theri is one utility called Everest from
http://www.lavalys.com or www.download.com
This will tell you your Motherboards RAM Capability
satyamy is offline
Old 12-08-2006, 10:09 PM   #3 (permalink)
Stalker's Avatar
i had checked it using @BIOS agent and it had said tat the max capacity was 512 mb.......................will try everest
Stalker is offline
Old 12-08-2006, 10:26 PM   #4 (permalink)
d
yea the clock speeds have to match i think.. else some mobos have an order of slots to put in diff speeds.. as in fastest in slot 0, next in slot 1 .. like that.. perhaps you cld check that out in the manual..
The torquemaster rules.
d is offline
Old 13-08-2006, 08:25 PM   #5 (permalink)
Stalker's Avatar
got everest...........ran report wizard says
Memory Controller Properties:
Error Detection Method 8-bit Parity
Error Correction None
Supported Memory Interleave 1-Way
Current Memory Interleave 1-Way
Supported Memory Speeds 70ns, 60ns
Supported Memory Types ECC, SDRAM
Supported Memory Voltages 3.3V
Maximum Memory Module Size 4096 MB
Memory Slots 2
does it mean that i have 4 GB RAM capacity?? wat is ecc ram??
this hasn't helped by problem. plz advice...
Stalker is offline
Old 13-08-2006, 11:19 PM   #6 (permalink)
vandit's Avatar
Location: If I had a webcam u could have seen me, before your eyes.
ya the clock speeds have to match
Searching for dell studio 15 ??
dell studio 15 review @ my blog
vandit007.blogspot.com
And remember the stylus that comes along with the touchscreens isnt meant for cleaning your ears !!
vandit is offline
- by c4u
