Old 12-08-2006, 08:42 PM   #1 (permalink)
d
Default blank screen after resolution switch.
there seems to be a problem whenever i switch resolutions.. for example.. when i run windows media player in fullscreen resolution.. or when i run the command prompt in fullscreen.. and i switch back.. or exit the visualisation, my screen goes totally blank and all i can see is .. the mouse pointer.. sometimes i can't even see that.. i'm forced to hard-reset everytime.. any ideas why this problem's caused? i'm running a 6800gt on AGP.. latest drivers i think.. with all the control panel eye candy..
thanks in advance..
The torquemaster rules.
d is offline
Old 12-08-2006, 09:18 PM   #2 (permalink)
Stalker's Avatar
Default Re: blank screen after resolution switch.
reinstalling ur OS may fix the problem........i think
make sure u have the latest drvrs & directX version
| C2Q Q6600 G0 | Intel DG33FB | 4 GB Corsair 6400C5G DDR2-800Mhz | XFX 8800GTX | CM Extremepower 600W | 250GB Seagate HDD | Lite-ON 1635S DVD RW | Logitech MX-518 | Zalman RS6F | APC RS 800 |
Stalker is offline
Old 12-08-2006, 09:38 PM   #3 (permalink)
thug for life...2pac
PainKiller's Avatar
try re-installing display driver before re-installing the entire os
e8400:)|abit ip35-e|transcend 1x2gb 800mhz|evga 8800gt sc:)|wd 320gb sataII|moser baer 20x sata|corsair vx 450w:)|cm elite 332|altec lansing atp3:)|15" crt (lg 226wtq soon)|kboard/mouse:samsung/ms
PainKiller is offline
Old 12-08-2006, 09:43 PM   #4 (permalink)
d
well.. i've just reinstalled my OS... and the display driver along with it.. so perhaps i should switch to an older version? anyone knows any known issues with this version?
d is offline
Old 12-08-2006, 09:54 PM   #5 (permalink)
Stalker's Avatar
r u using the 91 series forceware drivers?? i feel that the older 81 series r quite stable.
did this problem occur when u upgraded ur video drivers??
Stalker is offline
Old 12-08-2006, 10:11 PM   #6 (permalink)
d
yea i guess... i changed my video card too at the same time.. maybe i should do a driver rollback and install the older drivers... cos vista runs fine.. and it uses just the nvidia drivers.. didnt install the nvidia control panel thing..
d is offline
- by c4u
