Old 12-08-2006, 02:57 AM   #1 (permalink)
singh's Avatar
Exclamation problem with s-video cable
i have an s-video cable which is around 1 meter in length i want to extend it around 15 metres , please help me with this
---- is there a way by using utp cable
singh is offline
Old 12-08-2006, 07:37 AM   #2 (permalink)
varkey's Avatar
Default Re: problem with s-video cable
why dont u use a composte converter.
Intel Core 2 Duo E6300 @ 1.86 GHz | Intel DG965WH | 2x1GB DDR2 667 MHz Transcend | Seagate 320 GB SATA II | Sony DW-Q120A | Samsung 940bw 19" LCD
varkey is offline
Old 12-08-2006, 07:04 PM   #3 (permalink)
S-Video at 15m length is quite close to the upper limit and will pick up a lot of interference. Not recommended. If if you do want to try this, get a good brand (Monster) as quality of shielding is paramount. If you do observe any chroma an luma separation, you may need an s-video amplifier in between. Better still, try to splice it into a component cable run and then splice back to s-video, This'll give you about thrice as much range without need for ramping up the signal.
Cheers,
-k
Keith Sebastian is offline
Old 13-08-2006, 02:18 AM   #4 (permalink)
TechGuru#1's Avatar
^^ what is the UPPER LIMIT for length as in Component RCA cables 2 be used for DVD players without loosing signal gains?
TechGuru#1 is offline
- by c4u
