Old 12-08-2006, 12:27 AM   #1 (permalink)
crazybutt's Avatar
Default intel 865 v/s 845
halo again
wanted to ask if 865 chipset intel mobos have bettr onboard graphics than intel 845 ones...i have this 845 mobo which im thinkin of replacing wid a 865 one (sorry, but current budget limits are set to these)
also, if the ans to above quesn is yes, do suggest a good intel board (wid 478 socket) which is on the cheaper side but "good" onboard graphics
a quick reply would be appreciated!!
Fate likes to play a little game called "up yours, moe"
crazybutt is offline
Old 12-08-2006, 01:11 AM   #2 (permalink)
Default Re: intel 865 v/s 845
A intel845 chip based MB is cheaper and Available any time and any where. But if u r looking for better OBG and feature, 865 is better choice than 845.
pops is offline
Old 12-08-2006, 10:27 AM   #3 (permalink)
there is very small difference in performance of onboard gfx b/w 845 and 865, only advantage in 865 is that u can get AGP 8X slot
signature??? :???: Let Me Think About It!!!:-D
paul_007 is offline
Old 12-08-2006, 10:30 AM   #4 (permalink)
Commander in Chief
QwertyManiac's Avatar
If you can find, get an 875 maybe, there will be a small boost, more from 865 in it.
The onboard graphic wont get you anywhere, I'd suggest buying an 865 GBF along with a card like 5700 or 5200 at minimum, if not the 6 series of GeForce.
Harsh J
www.harshj.com
QwertyManiac is offline
Old 12-08-2006, 11:42 AM   #5 (permalink)
GeekyBoy's Avatar
Lightbulb Re: intel 865 v/s 845
You can go for the Intel 865GBF mobo which features Intel Extreme Graphics 2.But as socket 478 processors will be discontinued not far from now,I suggest you wait a little while,let the AMD AM2 prices fall and buy a good mobo or just buy a socket 939 mobo like asus a8n vm csm coupled with a good processor like AMD Athlon 3500+ or AMD X2 4400+.The AMD mobo offers much better performance-it has the Geforce 6150 IGP.
Intel Core i3 2100 //4GB Corsair DDR3 1333 RAM //Intel DH61WW//Sony AD-7260S DVD-RW//Samsung 2033SW Monitor//Windows 7//Seagate ST3250310AS 250GB HDD
GeekyBoy is offline
Old 12-08-2006, 06:06 PM   #6 (permalink)
which cards are available in the market for AGP 8X
paul_007 is offline
Old 12-08-2006, 09:21 PM   #7 (permalink)
Stalker's Avatar
well an 865 is definitely better, bcoz some 865 chipsets have support for dual-core, 64-bit processing.
anything from geforce 4 to geforce 6600
| C2Q Q6600 G0 | Intel DG33FB | 4 GB Corsair 6400C5G DDR2-800Mhz | XFX 8800GTX | CM Extremepower 600W | 250GB Seagate HDD | Lite-ON 1635S DVD RW | Logitech MX-518 | Zalman RS6F | APC RS 800 |
Stalker is offline
Old 12-08-2006, 09:34 PM   #8 (permalink)
samrulez's Avatar
And da 6800 ultra....and some of the other 6800*** cards....
Sam :D Rulez :lol:
samrulez is offline
Old 12-08-2006, 10:49 PM   #9 (permalink)
Commander in Chief
Stalker - Which board of 865 chipset has a dual core support ? :O
I heard that even one of the 7 series comes on AGP, true ? 7300 or something, not sure.
Harsh J
www.harshj.com
Old 13-08-2006, 10:55 AM   #10 (permalink)
Stalker's Avatar
@QwertyManiac
my friend got a gigabyte 865 mobo with dual-core support & AGP 8X support
will post the model no. later in this thread.
well i think most of the 7 series are PCI-E based, however u may find some entry-level 7 series cards in AGP..............very rare though
Stalker is offline
Old 13-08-2006, 11:02 AM   #11 (permalink)
i dont think 865 mobos support dual cores proccy,
my friend is having intel 2.26 ghz proccy, 1 GB 266 Mhz DDR ram , intel 865 mobo with 8X slot ,
so is 6800 GT,XT or ULTRA is good card?? , my friend is just a casual gamer , will all the games till now run at 640x480 or 800 x600 resolutions with medium settings.
paul_007 is offline
Old 13-08-2006, 11:16 AM   #12 (permalink)
Stalker's Avatar
guys, check out these mobos
http://www.gigabyte.com.tw/Products/...e=GA-8IPE775-G
http://www.gigabyte.com.tw/Products/...-8I865GVMK-775
http://www.gigabyte.com.tw/Products/...A-8I865GME-775
http://www.gigabyte.com.tw/Products/...A-8I865GMK-775
http://www.gigabyte.com.tw/Products/...GA-8I865G775-G
http://www.gigabyte.com.tw/Products/...8I865G775-G-RH
these 865 mobos support DUAL-CORE processing
Stalker is offline
Old 13-08-2006, 11:30 AM   #13 (permalink)
thnx 4 information, i didnt knew such mobos existed, but they r for socket 775 procc.
paul_007 is offline
Old 13-08-2006, 12:08 PM   #14 (permalink)
dOm1naTOr's Avatar
Will it run????hell YES.6800GT or any varien can handle any game at 1600x1200 at max details(tun of some effects like bloom, HDR etc.all will be fine).
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 13-08-2006, 12:28 PM   #15 (permalink)
i am talking about AGP 8x , r u sure??
paul_007 is offline
Old 13-08-2006, 12:46 PM   #16 (permalink)
Stalker's Avatar
6800 GT will handle any game, but i think the AGP variant requires additional power supply.
@paul_007
yes, the mobos support the lga 775 socket
Stalker is offline
Old 13-08-2006, 01:23 PM   #17 (permalink)
my friend is having 350 W supply, does it require more than that..
paul_007 is offline
Old 13-08-2006, 03:40 PM   #18 (permalink)
Commander in Chief
Yes, keep atleast something like 450 since even drives and other parts suck power. For a graphic card, best practice is to have atleast 400w
Harsh J
www.harshj.com
Old 13-08-2006, 04:09 PM   #19 (permalink)
Stalker's Avatar
agree with QwertyManiac, high-end graphics card require at least 450 W
Stalker is offline
- by c4u
