Old 11-08-2006, 04:53 PM   #1 (permalink)
rachitboom2's Avatar
Exclamation How to disable HDD, but Temporarily ???
Hi all,
One of my cousins had got one of his HDD to be corrupted and now hi is asking one of my spare HDD for some time,
and I know that if I give it to him I wont get it back soon,
so pls tell me that is there any way to disable or corrupt my HDD temporarily so that I wont have to give it to him, and pls also tell me how make it run again ???
Thanks in advance !!!
Laptop: HP DV6 - 6017TX: Intel Core i7 + 4GB DDR3 + ATI HD6770
Cell Phone: NEW Samsung Galaxy S2 i9100 16GB
Consoles: 3x Xbox 360 Slim 250GB Gamertag: Rachitmayhem
3x PS3 320GB Slim Gamertag: Rachitmayhem
mahule_rachit@yahoo.com
rachitboom2 is offline
Old 11-08-2006, 05:24 PM   #2 (permalink)
Beware of the innocent
ilugd's Avatar
Default Re: How to disable HDD, but Temporarily ???
just say no man. Don't mess with the hard drive.
Life is too short. Have fun.
ilugd is offline
Old 11-08-2006, 08:10 PM   #3 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
lol...
1st method: Just enter into BIOS settings and set all boot device orders to disable.
2nd method: Open cabinet and remove the power cable from ur HDD.
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 11-08-2006, 08:20 PM   #4 (permalink)
shashank4u's Avatar
load linux or other operating system in that spare hdd..
and u know what to say..
Be like a postage stamp-stick to one thing until you get there.
shashank4u is offline
Old 11-08-2006, 08:21 PM   #5 (permalink)
Google Bot
Pathik's Avatar
yup disable the hdd from the bios.
Pathik is offline
Old 11-08-2006, 09:06 PM   #6 (permalink)
Stalker's Avatar
install linux on the harddisk, in that case it won't be detected in windows
has anyone got a better idea?? i somewat have the same problem
| C2Q Q6600 G0 | Intel DG33FB | 4 GB Corsair 6400C5G DDR2-800Mhz | XFX 8800GTX | CM Extremepower 600W | 250GB Seagate HDD | Lite-ON 1635S DVD RW | Logitech MX-518 | Zalman RS6F | APC RS 800 |
Stalker is offline
Old 11-08-2006, 11:00 PM   #7 (permalink)
Oh,
sorry none of you are understanding my prob,
he will take it from me and then he will attach it in his system and then reinstall XP using a bootable CD as he dosent have any OS currently !!!
So, none of your sugestions would help me !!!
Old 12-08-2006, 01:56 AM   #8 (permalink)
Very Sorry!!! There is one easy way. Simply disable it from your BIOS or loose the power cable!!!
If u Dont like u may......
U Have not maintained what type of HD, As SATA or ATA type.
If u have ATA type then u have another option, u can try. Plough another CD-ROM or a HD to the same cable. Then change Master/Slave jumper. Do same for both drive, which ll make confusion and Your HD will not readable for your computer. But in this case u r going to block both the device!!!! Sorry. Later u can change all the setting to back.
(Another option is limited 32GB to give illusion any one as bad-sector HD!!!! But make sure u back-uped ur data!!!!!!! Before changing the jumper for this trick!!!)
pops is offline
Old 12-08-2006, 10:24 AM   #9 (permalink)
Just look him in the eye and say an emphatic... NO !!!!
I have learned this the hard way - people borrow but never lend and never return in same condition so I now just say a big fat .... NO !!!! I dont bother to give a reason as you will find the borrower will try his best to knock down the escuses you give. I firm NO is the end of the discussion.
suman2005 is offline
Old 12-08-2006, 01:28 PM   #10 (permalink)
siriusb's Avatar
If you are willing to go the extra mile to deny your cousin of your hdd, and you have no qualms de-soldering and re-soldering an smd, just desolder a couple of resitors/caps/chips or whatever is easily accessible on the pcb. As soon as he leaves, resolder'em back on. Just hope that you didn't remove the wrong ones o.o
Or, more practically, just hide it in you closet and tell him you gave it away or something.
http://myxp.blogspot.com
Winchester 3200+ @2,500MHz
siriusb is offline
Old 12-08-2006, 08:23 PM   #11 (permalink)
d
yea mate.. simplest is to disable the hard drive from the BIOS.. the next one's to disconnect power.. you should be able to resume as you'd left as soon as you're done with it..
The torquemaster rules.
d is offline
Old 12-08-2006, 09:08 PM   #12 (permalink)
Stalker's Avatar
just say no!....or something like 'u have given it to a friend'. don't mess with the harddisk
Stalker is offline
Old 12-08-2006, 09:36 PM   #13 (permalink)
Alive Again...
satyamy's Avatar
I too have a same problem like rachitboom2
but none of your suggestion is good & working for me
satyamy is offline
Old 12-08-2006, 11:01 PM   #14 (permalink)
d
satyamy.. what is the problem that you're having? why don't any of the solutions fit you?
d is offline
Old 13-08-2006, 10:38 AM   #15 (permalink)
Stalker's Avatar
well, i think they both don't want their drives to be detected on their friend's comp but function on their own comp only............right??
well, i have the same sort of problem.......any ideas????
Stalker is offline
Old 13-08-2006, 09:01 PM   #16 (permalink)
pop143's Avatar
how abt selling ure HDD to him..! mean..if u dont use it frequent...bcoz..that peice wont go for any cost after some years...!!
pop143 is offline
Old 14-08-2006, 12:04 AM   #17 (permalink)
Learner
Kniwor's Avatar
http://www.popularshareware.com/HD-X...hot-28972.html
u can try this
Kniwor is offline
Old 14-08-2006, 12:10 AM   #18 (permalink)
bharat_r's Avatar
there was some software called Starforce Nightmare which was used to play Star force protected games..u can disable the hard disk with that..
bharat_r is offline
Old 14-08-2006, 12:40 AM   #19 (permalink)
String Phreak
mediator's Avatar
Just hide the windows partition!
mediator is offline
Old 14-08-2006, 05:00 PM   #20 (permalink)
ayush_chh's Avatar
i don't know it will work or not but try
changing the jumper setting........
make it slave......
or limit its capacity........
eXPerience is what a MAN learn's fROM.....
ayush_chh is offline
Old 14-08-2006, 07:57 PM   #21 (permalink)
ilugd's Avatar
hey, let us get the question clear ok. He needs to take and give out the harddrive to his cousin. So no bios changes will persist. And changing the jumper settings or setting the harddrive to slave and all is just a matter for noobs. If a guy can install a harddrive in his sys, he will know how to set a harddrive as a master or whatever. (Not that it will matter anyway). What this guy seems to be asking is if he can make the hardware fail temporarily and any such changes can only be done on the harddrive. The only answer which came even near this problem was by @siriusb.
ilugd is offline
Old 14-08-2006, 08:00 PM   #22 (permalink)
Let the music play.....
djmykey's Avatar
Most hideous reply :O
I dont think that we can do anything like that. Am not sure coz u will have to edit his bios then for it not to be detected.
djmykey is offline
Old 14-08-2006, 11:15 PM   #23 (permalink)
Stalker's Avatar
no.....u can only disable CD/DVD drives using tat.
Stalker is offline
Old 14-08-2006, 11:59 PM   #24 (permalink)
siriusb's Avatar
Why thank you!
A more less-adventurous (ha) method would be to tamper with the wires leading off the male molex connectors on your hdd (if your hdd is not sata). Just cut the 5V(red) or the 12V(yellow) wire with a plough knife and stick it back with super-glue. Super glue is non conductive and will not conduct. At the same time, everything will appear fine. (Go ahead and let out an evil snicker while your cousin's comp fails to detect the hdd!)
When you get it back, just scrape off the super glue and solder the wire ends. (and let out another eveil snicker)
Actually, apart from the "say no" reply, this is the third relevant reply to your question. But don't ever try out my suggesstions.
siriusb is offline
Old 15-08-2006, 03:03 AM   #25 (permalink)
No longer here..
okay...i have some nasty ones....
1.As someone said above that superglue is non-conductive how about ....coating the power connectors with a thin layer of superglue so that when he plugs it in.....the harddisk wont be detected coz no power to the harddisk....samething can be tried with the datacable pins on the harddisk.But the power connector way sounds better.The glue can be removed later by applying some alcohol with a paint brush or best thing will be paint thinner that can be bought from the hardware store...costs 30/- per litre.
i think that will do......
thank me....please if you liked my answer.....i am kidding...no need to thank......just tell me how everything went......
indian_samosa is offline
Old 15-08-2006, 05:53 AM   #26 (permalink)
ilugd's Avatar
hey super glue is inflammable right? I hate to think what would happen if it burns up due to a spark in the power connector.
Never tried it yet, but i bet it will to give some cool special effect smoke.
ilugd is offline
Old 15-08-2006, 08:42 AM   #27 (permalink)
Smile Re: How to disable HDD, but Temporarily ???
Hi Dear I m Navdeep
Go To The My Computer And Right Click On it
Then Go To The Manage Option And Then Got The Specific Drive Which U Want To Hide Just Right Click On Drive N ReMove its DriveLetter And C The Drive Does Not Shown in My Computer....
Thanx
With regrads,
NavDeep
navipta is offline
Old 15-08-2006, 09:15 AM   #28 (permalink)
No longer here..
ilugd.......
It doesnt need to flame up.......see what i am tryin to say is put some superglue ie a fine coat just so that there is no open space left on the connector.....kinda like coating it in paint.Why superglue .......coz it dries nastily fast ....leaves no trace of ever being used ie visually....and finally he is not going to plug the molex connector when his pc is on by theway......so there is no need for sparking to take place.its just like inserting a plug into the socket with the plug covered with insulation.
Apply one coat.....wait for sometime for it to dry.....then apply another ...try some more times.....so that the coating becomes thick.
PS: doesnt require to coat all the four connectors.Only coat the red one and the yellow one.(not the wires but the pins on the harddisk)
Old 15-08-2006, 06:30 PM   #29 (permalink)
ilugd's Avatar
ok, @indian will keep that idea in mind. May come in useful some day. The inflamable stuff was just a query. No offence meant. OK??
ilugd is offline
Old 15-08-2006, 09:09 PM   #30 (permalink)
No longer here..
ilugd.......dont worry yaar.....
no offence taken on this side either......
We can learn.......after all we seek knowledge .All of us.
And also thats what forums are for .....sharing info and bashing each other's views .....with a noble thought...that is.
cheers.Thinking about hatred is the last thing a person can do....and also there isnt much time in guy's ilfe to waste time on thinking bad things about others.Hope i make my point clear.Feel free to comment ...the stage is all urs.
- by c4u
