Old 10-08-2006, 02:19 PM   #1 (permalink)
Default Need Tv Tuner card for Laptop
I need a tv tuner card for my laptop ...how much will it cost???
laptop has PCMCIA slot...Please reply if anyone has such or know where will it be available..Im presently in Bangalore
catchjaga is offline
Old 12-08-2006, 08:55 PM   #2 (permalink)
d
Default Re: Need Tv Tuner card for Laptop
instead of a PCMCIA tv tuner card, you could try using a USB tuner device, dude.. it'll be cheaper i think.. check out pinnacle's device.. you could always use it on a desktop too if the need arises..
The torquemaster rules.
d is offline
Old 13-08-2006, 05:19 AM   #3 (permalink)
King of my own Castle
freshseasons's Avatar
Use XFX Pcmcia Tv tuner card. Dont go for USB tv tunder card as they are bulky in size and impair the mobility of Laptop, unless ofcourse you are using Gainward TvGo usb . But its battary consumption is high.
freshseasons is online now
Old 14-08-2006, 12:16 PM   #4 (permalink)
Hell Sucks!!!
Hi Frnds
How mch wl the PCMCIA Card and USB card cost ?
Is there a cheap solution out there, of course with a good quality
ashu_dps is offline
Old 16-08-2006, 12:12 PM   #5 (permalink)
@freshseasons we need the price of Gainward Tvgo please
- by c4u
