I've a vcd with me which contains a few songs...It has got a default player n the songs r runnin only in that player and i cnt copy it since the files r not visible inside the directory..while opening the MPEGAV folder it says that the drive is missin..n all..ie, actually the files are protected. But i need to copy those files ..how can i do it...?? Any idea...???
regards
Windchimes
