Old 08-08-2006, 04:05 PM   #1 (permalink)
Default which Mobo & Process ?
guys i am confused .... thinking a lot in fact !!!
Config I :
i thinking of going for Amd X2 4800+ am2 with M2N32-SLI Deluxe/Wireless Edition... would like to cost of x2 4800+ am2 ....
i heard M2N32-SLI Deluxe .. sells around 15k
can i get both at around 25k ?...
Config II :
or should i buy to Amd x2 4800+ 939 Pin....with ASUS A8N-SLI Deluxe ...
pls Indicate the cost for both config
vinyas is offline
Old 08-08-2006, 05:59 PM   #2 (permalink)
samrulez's Avatar
Default Re: which Mobo & Process ?
the config II is good........but u cannot upgrade the processor after this year to a newer X2.......
config I is also good but might be a little pricey!!If u can get the config then get it!!better,!!,,but no idea how much it will cost U!!
Sam :D Rulez :lol:
samrulez is offline
Old 08-08-2006, 10:02 PM   #3 (permalink)
Cannot upgrade processor ? Kindly enlighten more. Thx.
suhas_sm is offline
Old 09-08-2006, 07:06 PM   #4 (permalink)
samrulez's Avatar
Well..........amd is going to stop manufacturing X2 processors for except the except X2 4800+...in the 939 family.....
Sam :D Rulez :lol:
samrulez is offline
Old 09-08-2006, 09:08 PM   #5 (permalink)
GeekyBoy's Avatar
You cannot upgrade the processor because all s939 processors are being discontinued this year......
Intel Core i3 2100 //4GB Corsair DDR3 1333 RAM //Intel DH61WW//Sony AD-7260S DVD-RW//Samsung 2033SW Monitor//Windows 7//Seagate ST3250310AS 250GB HDD
GeekyBoy is offline
Old 10-08-2006, 12:23 AM   #6 (permalink)
Omg so whats the new tech now ? Does that mean a8n-e is not a good mobo considering future expansion.
suhas_sm is offline
Old 10-08-2006, 02:50 PM   #7 (permalink)
samrulez's Avatar
the new tech is AM2 it supports AM2........peformancewise A8N-E is good.....only thing is dat u cannot upgrade the procey after this year!!
Sam :D Rulez :lol:
samrulez is offline
Old 10-08-2006, 07:26 PM   #8 (permalink)
So which mobo would you suggest now keeping future expansions in mind ?
suhas_sm is offline
Old 10-08-2006, 07:44 PM   #9 (permalink)
samrulez's Avatar
Get a 3500+ AM2 ....
For mobos see this
Sam :D Rulez :lol:
samrulez is offline
Old 13-08-2006, 03:03 AM   #10 (permalink)
wats the cost of x2 4800+ 939 ?
vinyas is offline
- by c4u
