Old 08-08-2006, 03:53 PM   #1 (permalink)
Default Six months old rig...still a good rig ?
Six months back i had this in mind...
AMD XP64 3400+
Asus A8NE sli
DDR2 1GB
XFX 6600gt
is still a good option ? Oe do i have better options avalaible ?
I m looking forward for a good mid-range Gaming PC with future expansions availability.
Thank you
suhas_sm is offline
Old 08-08-2006, 04:12 PM   #2 (permalink)
AmbarD
Posts: n/a
Default Re: Six months old rig...still a good rig ?
wats ur budget?
if its around 35K
amd 3500
asus a8ne
geforce 7600 gs
250 gb /160 hdd
2 gb ram
etc etc
Old 08-08-2006, 04:15 PM   #3 (permalink)
Hmmmm
a8ne wuld be sli ?
geforce 7600gs cost ?
and rest all if fine. Budget max upto 50k.
suhas_sm is offline
Old 08-08-2006, 05:53 PM   #4 (permalink)
samrulez's Avatar
a8n-e sli would cost u 6.5k.....
7600GS....8k
Sam :D Rulez :lol:
samrulez is offline
Old 08-08-2006, 06:16 PM   #5 (permalink)
Amd 64 3500 : around 5k i think
X2 3800: 8k+
Asus A8N E, not sli : around 5k+
Geforce 7600GT, better still X1800GTO, better still 7900GT, starting around 10.5k
2gb ram, 1gb X 2
akshayt is offline
Old 08-08-2006, 10:00 PM   #6 (permalink)
I m looking for SLI only...keeping expansion on mind.
Dont u think SLI will be better... ? And AFAIK it supports most the coming tech. :S
How much 1 GB x 1 would cost me ?
Is A8N-e SLI compatible with x2 ? Right now i m going for 3500+ to reduce final costing. I may upgrade may be after six months or a year.
suhas_sm is offline
Old 09-08-2006, 01:07 AM   #7 (permalink)
deathvirus_me's Avatar
well .. now that u have the 7950GX2 and 7900GX2 out .. and the A8N-E officially supporting it .. i don't think SLi is really necessary now ..
Also .. about a midrange PC i'd suggest :
X2 3800+ , A8N-E , 1 GB DDR400 , 7600GT ...
deathvirus_me is offline
Old 09-08-2006, 10:06 AM   #8 (permalink)
dOm1naTOr's Avatar
If your budget is 50k, then
AMD 3500+: 5.5k
ASUS A8N SLI Deluxe.: 6.4k
2x 1gb: 8.5k
7800GT: 20k
250GBx2 in raid0: 7.8k
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 09-08-2006, 11:44 AM   #9 (permalink)
Cant afford to put 20k in graphics card the question will come why do i need such a good graphics card .. cant answer for GAming
A card better than 6600 Gti PCI-e within budget of 8-10k would be fine wid parents
OK this is wat i m finalising
x2 3800+/64 3500+
A8n-e sli deluxe
7600gt 256mb/7600 gs 256
1 gb ram
plus rest all ......
Stil confused about CPu and G C combo though
suhas_sm is offline
Old 09-08-2006, 01:00 PM   #10 (permalink)
your budget doesn't allow sli. By the time you can afford another graphic card, you will get a single graphic card which is more powerful that the two combined.
No point.
Get a single 7900GT or 1900XT if you want that much power.
I understand your position. Don't tell your parents the cost of individual components, just of the entire set.I didn't tell them what I spent on my upgradation.
In case you can't do that get:
Amd X2 3800
Asus A8N E, not SLI
2 X 1GB DDR 400 Transcend UCCC chips
Radeon X1800GTO
300GB SATA II NCQ HDD
Cooler Master iGreen 500
akshayt is offline
Old 09-08-2006, 01:26 PM   #11 (permalink)
Ram i ll upgrade after a couple of months so going for 1 Gb right now.
X1800GTO better than 7600 Gs or GT ? whats it cost ? Is it PCi-E ?
Also the reason i m ready to cut down on RAM and GC is for betetr mobo so that i can expand rig further in future.
Is ddr2 compatible with a8n-e ?
suhas_sm is offline
Old 09-08-2006, 09:18 PM   #12 (permalink)
GeekyBoy's Avatar
no
ddr2 is not compatible with a8n-e
Intel Core i3 2100 //4GB Corsair DDR3 1333 RAM //Intel DH61WW//Sony AD-7260S DVD-RW//Samsung 2033SW Monitor//Windows 7//Seagate ST3250310AS 250GB HDD
GeekyBoy is offline
Old 10-08-2006, 02:54 PM   #13 (permalink)
samrulez's Avatar
If u want DDR2 then u will have to move to AM2....
Sam :D Rulez :lol:
samrulez is offline
Old 10-08-2006, 07:27 PM   #14 (permalink)
Hmmm now me perplexed wat to buy T_T
suhas_sm is offline
Old 10-08-2006, 07:37 PM   #15 (permalink)
AmbarD
Posts: n/a
wudnt e6300 + 965 based mobo be good combo?
some 965s have onboard gfx which support dx10 i think
so why not buy that and get a dx10 cad after some time?
Old 10-08-2006, 10:25 PM   #16 (permalink)
dOm1naTOr's Avatar
I suggest u to wait a month or so till AM2 bcomes std. U will get most future proof mobo on AMD or Intel side(for conroes) by that time.
G3: XPS M1530 |
FZ 16.
Old 11-08-2006, 07:47 PM   #17 (permalink)
How is chieftec in cabinets ? ? ?
A dealer showed bg-BG-01B-B-B from it. I found it awesome. Wat say ?
It was 5k he said.
suhas_sm is offline
Old 11-08-2006, 07:50 PM   #18 (permalink)
Commander in Chief
QwertyManiac's Avatar
Any cabinet with enough fans and ventilation will do
Harsh J
www.harshj.com
QwertyManiac is offline
Old 11-08-2006, 07:54 PM   #19 (permalink)
http://www.chieftec.com/products/Silver/BG-01B-B-B.htm
the power supply had 5 and half inch fan :O So i found it good. It comes with 2 more fans fitted in cabinet and has 3 more ventilation rooms to fit equals no. of fans of 2 and half inches. (not sure of the fan sizes)
Though he showed me even better cabinets but those were good for servers. For desktop considering budget in mind i found this great.
suhas_sm is offline
- by c4u
