Old 06-08-2006, 06:23 AM   #1 (permalink)
cooldip10's Avatar
Arrow Can anyone help???
I've recently bought a 5.1 home theatre system (Phillips MMS 5.500i), My mobo is Intel 845 GVSR with inbuild sound card ( Realtek AC97 Audio)...
The problem is the speaker is unable to produce 5 channel sounds , i.e all its speakers aren't working although beig connected to computer >>> Any ideas about this matter..
Everything is Possible
cooldip10 is offline
Old 06-08-2006, 06:31 AM   #2 (permalink)
Venom's Avatar
Default Re: Can anyone help???
This is for linux or generally? You have to enable 5.1 for your ICH5 or whichever soundcard first.
From now on we are poison to you, that's why we call ourselves, the Venom!
Venom is offline
Old 06-08-2006, 10:28 AM   #3 (permalink)
TechGuru#1's Avatar
Wink Re: Can anyone help???
For Stereo i.e any 2 channel audio(majority of songs-mp3,VCD's & some DVD's) this is what is going 2 occur by default,'coz that philips doesn't have an external 6 channel hardware audio decoder,which would artificially create 6 channels of audio for ur 5.1 spkrs system as by using audio alogrithms of dolby prologic I,II,etc,so ur best bet is 2 use software & 5.1 channel plugins for creating artificially those 6 audio channels.Needless to say,that wouldn't be REAL perfect 6 channels but then all ur speakers would be working/making/throwing out sum sound!
Only when u use DVD's with movies(or for that matter any program material) encoded with actual 5.1 channel audio as in DOLBY DIGITAL,DTS,etc,can u get ACTUAL/REAL 6 channel audio output & for which u actually brought the HT in the first place!
mayb that's all to it folks
amen!
TechGuru#1 is offline
Old 09-08-2006, 10:48 AM   #4 (permalink)
cooldip10's Avatar
hey I found that my on board sound card doesn't support 6 channel spkr system... so can you recommend one PCI sound card with this support..
Old 09-08-2006, 11:41 AM   #5 (permalink)
No pain....No gain
john_the_ultimate's Avatar
For low budget go for Creative soundblaster Live 5.1, costs around 1-1.2K maybe less. For higher budget and no compromise in quality u can buy Creative audigy for about 2-3K or even get creative X-Fi for around 6-7K. There r many model for each series, so do check with local vendor for the exact pricing.
john_the_ultimate is offline
Old 09-08-2006, 01:04 PM   #6 (permalink)
Get Audigy 2 Value
audigy value series is about the same price as SB
akshayt is offline
Old 09-08-2006, 06:17 PM   #7 (permalink)
cooldip10's Avatar
Hey man.. I' gonna buy a new system next yr. So plz consider the range upto 1.5K... You know..
Old 09-08-2006, 07:01 PM   #8 (permalink)
samrulez's Avatar
Sound cards are available ranging from 700 bucks to 700 bucks.....depends on what quality of sound u want.. normal sound blaster 5.1 should cost u a k...
Sam :D Rulez :lol:
samrulez is offline
Old 10-08-2006, 12:58 AM   #9 (permalink)
creative audigy value should be around 1500 or so, try to get audigy 2 value if it is not much more expensive, don't know its price
akshayt is offline
Old 10-08-2006, 12:59 AM   #10 (permalink)
killerinstinct2's Avatar
depends on type of os u r usin
killerinstinct2 is offline
Old 10-08-2006, 05:13 PM   #11 (permalink)
I think your on board sound card doesn't support for 5.1. So you can now u can choose your best sound card from (www.soundblaster.com) as your budget.
Krishna
kguragain is offline
- by c4u
