Re: Problem with FX 5200
Yah it is an AGP card,
now do one thing,
First of all plug in your card then start your comp in Safe Mode by pressing F8 after the POST screen,
if you are able to get the display then uninstall your old cards drivers then restart in safe mode and this time install the new drivers which you must have got with the card,
then restart your comp in normal mode, if done correctly you should the display and have instaled your card succesfully
But if at first only you are not getting display in safe mode also then try VGA mode by pressing F8 during the startup(Same as in safe mode) !!!
and the rest is same !!!
Laptop: HP DV6 - 6017TX: Intel Core i7 + 4GB DDR3 + ATI HD6770
Cell Phone: NEW Samsung Galaxy S2 i9100 16GB
Consoles: 3x Xbox 360 Slim 250GB Gamertag: Rachitmayhem
3x PS3 320GB Slim Gamertag: Rachitmayhem
mahule_rachit@yahoo.com
