Old 05-08-2006, 12:32 PM   #1 (permalink)
mera kutch nahi ho sakta
chesss's Avatar
Default Motherboard for x2 within 4500
So I am finally upgrading to a X2 3800
I need a lil help in choosing a mobo though
Budget: 4000-4500
Must-have
1. complete linux support - this I can look up myself, so if you know a board that has decent IG within my budget, then plz post
2. integrated graphics - the best I can get within my budget.
Thats about it! Other minor things that I need are amd cool-n-quiet thing, and generally non shaky board.
thanks
chesss is offline
Old 05-08-2006, 08:35 PM   #2 (permalink)
Smile Re: Linux compatible motherboard for x2 ?
Go for NVIDIA based MoBo as it has better linux support thru drivers (i m using MSI K8N SLI Platinum with NVIDIA nForce4 chipset and using Suse 10 OSS without any problem). ATI doesn't offer gud Linux support for its drivers (that's what i heard). Asus has NVIDIA 6150 chipset based MoBo which offer gud performance and also has onboard NVIDIA graphics. The updated BIOS takes care of X2 (I think new MoBos already have updated BIOS) so no problem there.
All the best!
Originally Posted by chesss
So I am finally upgrading to a X2 3800 .
Budget: 4000-4500
Must-have
thanks
monkey is offline
Old 06-08-2006, 02:40 AM   #3 (permalink)
chesss's Avatar
Default Re: Linux compatible motherboard for x2 ?
@monley I think you were referring to this board: A8n-vm CSM
Thanks for the suggestion man, Linux support looks solid, integrated graphics also look great.
Another board that is linux compatible: Msi K8NGM2-FID
Now can some quote their prices in India?
chesss is offline
Old 06-08-2006, 11:30 AM   #4 (permalink)
montylee's Avatar
I suggest u to got for AM2 socket board like Asus M2MPV-VM which also has Nvidia 6150. I also wanna know the prices of the same.
Intel Core 2 Duo E6300, Intel DG965RY, MSI 8600GT OC, WD 250GB SATA-II Harddisk, Transcend 1GB 667 Mhz DDR2 RAM, Samsung Samtron 55V, Sennheiser HD485 cans, Zebronics LAVA Cabinet, Zebronics 400W PSU
montylee is offline
Old 06-08-2006, 03:11 PM   #5 (permalink)
I don't know about Asus' price but MSI K8NGM2-FID can be had from Rs. 5700/- (tax included) in delhi.
monkey is offline
Old 06-08-2006, 09:52 PM   #6 (permalink)
hey b4 goin for am2 b sure..u have am2 cpu...and more importantly....ddr 2 rams.......normal ddrwont fit on it.....
magnet is offline
Old 26-09-2006, 12:43 PM   #7 (permalink)
boomstation2's Avatar
Smile Re: Motherboard for x2 within 4500
Budget: 4000-4500
Must-have
thanks
I think u have decided to go for AMD Athlon 64 3800+ X2 (Socket AM2)
Go for AM2 sockets.
AM2 runs only DDr-2 RAMS which r faster than DDr Rams.
The compatible boards are:-
1. MSI K9NGM2
2. MSI K9NGM
3. ASUS M2NVM DH
4. ASUS M2NPV-VM
PLs get the prices for those.. 1st and 3rd shudbe ur first choice. Other things u decide on budget.
If u getthe pricesses for those...pls let me know. Even i am going for same combination.
boomstation2 is offline
Old 26-09-2006, 03:25 PM   #8 (permalink)
gooby pls
Third Eye's Avatar
Default Re: Motherboard for x2 within 4500
Budget: 4000-4500
Must-have
thanks
Get a AMD 3800 Processor.
Third Eye is online now
Old 26-09-2006, 11:39 PM   #9 (permalink)
Dhaval's Avatar
Go for AM2 sockets.
1. MSI K9NGM2
2. MSI K9NGM
3. ASUS M2NVM DH
4. ASUS M2NPV-VM
My friend just got himself the following configuration yesterday, maybe this will help
ASUS M2NPV-VM - Rs 4600/-
AMD Athlon 64 3600+ X2 (Socket AM2) - Rs 6600/-
earlier we had a very bad experience with ATI based motherboards couldn't install linux on it, so this time we went for nVidia based MB. Haven't yet installed linux on it, but will be doing soon.
and yes it does need DDR2 ram.
Cheers
DhavaL
AMD Athlon 3000+, Asus A8n MB, 1 GB , nVidia GeForce 7300 GT ....
Dhaval is offline
- by c4u
