Old 05-08-2006, 12:42 AM   #1 (permalink)
dOm1naTOr's Avatar
Default 7600GS or GT??
Im goin for a new system nd looking for a good gcard...nd a lil bit confused.
My vendor has 7600GT for 13000/- nd a GS for 7.5k. Both from XFX.
The GS has gr8 value for money but confused of its perfomance. Is GT really that gr8 for the perfomance??
Can anyone give benchmarks/links of the perf diff b/w 7600GS nd GT???
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 05-08-2006, 01:08 AM   #2 (permalink)
TeChRocK's Avatar
Default Re: 7600GS or GT??
yep 7600gt way to go
i got this card for 11.9k in hyd
TeChRocK is offline
Old 05-08-2006, 01:13 AM   #3 (permalink)
dOm1naTOr's Avatar
Is there really that much perfomance diff b/w the two????
Also which brand do u get??
G3: XPS M1530 |
FZ 16.
Old 05-08-2006, 01:20 AM   #4 (permalink)
TeChRocK's Avatar
i got leadtek brand,
the difference btw 7600gt&gs
http://www.gpureview.com/show_cards....=385&card2=387
TeChRocK is offline
Old 05-08-2006, 01:29 AM   #5 (permalink)
dOm1naTOr's Avatar
which of 7600GT the cheapest:
ASUS,MSI,Gigabyte,XFX???
Is 7600GT available in 128MB?
Thnx for the link
G3: XPS M1530 |
FZ 16.
Old 05-08-2006, 01:40 AM   #6 (permalink)
TeChRocK's Avatar
Thnx for the link
hmm i cant decide all r gud brands, there is no 128mb 7600gt
so wot have u decided ur going to upgrade ur pc?
TeChRocK is offline
Old 05-08-2006, 01:45 AM   #7 (permalink)
dOm1naTOr's Avatar
I think i could make either of these 2 options practical:
goin for x2 3800+ instead of 3500+
or
7600GT instead of GS:
which is better??nd futureproof??
G3: XPS M1530 |
FZ 16.
Old 05-08-2006, 01:52 AM   #8 (permalink)
TeChRocK's Avatar
or
get 7600gt it can handle latest games med-high, yes go for x2 3800
or wait for few weels, get core 2 duo cpu e6300 for 11k and mobo 8-11k.(future proof)
TeChRocK is offline
Old 05-08-2006, 02:05 AM   #9 (permalink)
gxsaurav
Posts: n/a
go for 3800+ & 7600GT, if your budget allows
however 3500+ & 7600GS will be good, but your graphical performance will be about 30% less
Old 05-08-2006, 02:58 AM   #10 (permalink)
deathvirus_me's Avatar
7600GT all the way if u can afford it ... the one ur vendor offered is the XXX ver. factory clocked at 590/1600 ... and should be better than a 6800U ..
And about the CPU ..get a 3200+ ... it should easily be able to handle 2.4 GHz (aka 3800+) ...
deathvirus_me is offline
Old 05-08-2006, 10:01 AM   #11 (permalink)
dOm1naTOr's Avatar
Is there any ATI cards in that price range nd vista ready?
G3: XPS M1530 |
FZ 16.
- by c4u
