Old 05-08-2006, 12:41 AM   #1 (permalink)
Default Sony DVD Writer Problem
I recently purchased a DVD writer . It was working fine till now , but today when i tried to write a DVD , it took between 40-50 minutes . I tried the blank DVD of various comp of 8x and 16x but the result was same . What could be the problem .
\" I Do not like to repeat success , i like to move on to other things \"
mako_123 is offline
Old 05-08-2006, 12:05 PM   #2 (permalink)
The Thread Killer >:)
phreak0ut's Avatar
Default Re: Sony DVD Writer Problem
Have you been writing at the maximum speed? Also, how much of data did you write on to the disc? Remember you are writing GBs of data onto the disc. I think its pretty much alright 'coz my friend burned a 4GB disc and it took him around 30-45mins. Try Googling for the answer as well.
phreak0ut is offline
Old 05-08-2006, 12:21 PM   #3 (permalink)
what r u kidding? i wrote 4.2gb of data on my lite-on 1635s at 6x speed under 10 min! which means at 16x it will take less than 5 minutes!! may be its the problem with the writer itself?
neyo is offline
Old 05-08-2006, 12:25 PM   #4 (permalink)
gooby pls
Third Eye's Avatar
My Cd-Dvd wirte also take 30-35 min to burn 4.35 GB data through nero 7 at maximum speed.
Third Eye is online now
Old 05-08-2006, 02:20 PM   #5 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
My Sony DVD RW DW-G120A takes 10 Minutes approx. to write a DVD!
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 05-08-2006, 05:02 PM   #6 (permalink)
In Pursuit of "Happyness"
kalpik's Avatar
It takes 6 minutes to burn a full DVD here with BenQ DW1650.
kalpik is online now
Old 05-08-2006, 10:23 PM   #7 (permalink)
My Sony DRU 810A takes little more than 8 minutes for a DVD movie.
V.Prem Kumar
janitha is offline
Old 05-08-2006, 11:37 PM   #8 (permalink)
I burned about 4.2 GB . Before this when i burned , it took around 10-12 mins but suddenly it is taking much longer . And i am also burning at maximum speed.
mako_123 is offline
Old 06-08-2006, 08:39 AM   #9 (permalink)
deathvirus_me's Avatar
What speeds did u burn at ?? 2.4x ???
deathvirus_me is offline
Old 06-08-2006, 08:55 AM   #10 (permalink)
Venom's Avatar
Maybe some settings is acting fault, do a nero disk check/scan of speeds and post the scores.
From now on we are poison to you, that's why we call ourselves, the Venom!
Venom is offline
Old 06-08-2006, 09:02 AM   #11 (permalink)
Hey here is the aks
arunks's Avatar
my sony dvd writer also just takes a maximum of 10 min to write a full 4.3 gb data on dvd
arunks is offline
Old 06-08-2006, 10:35 AM   #12 (permalink)
priyadarshi
Posts: n/a
mine too.
Old 06-08-2006, 06:19 PM   #13 (permalink)
prasad_den's Avatar
Is the writing speed in any way related to the configuration of the computer..??
prasad_den is offline
Old 06-08-2006, 08:34 PM   #14 (permalink)
i am writing it at 8X
mako_123 is offline
- by c4u
