Will any one explain me the difference between
serial, parallel, PS/2, etc...............i dont have much knowledge in hardware...........noteven basics!
also explain the differece on thir looks...like which type of pins?
I think u'll laugh on me on seeing this post. But plz laugh on me only if u can explain it to me!
When was the last time when you did something for the first time?
So many words for the broken heart.....
for world wars. ishangajera.blogspot.com
I think you should help yourself by searching. No one can explain everything to you and that too on an internet forum. You should start with google for your problems. Also, I would recommend following websites for reference. http://www.buildyourown.org.uk/ http://www.pcguide.com/ (PC Guide is the de-facto website for detailed info on almost every aspect of PC. An awesome reference...do check it out)
