Old 04-08-2006, 07:23 PM   #1 (permalink)
Default hdd badsectors removal...without use of floppy...:P
Is there any windows based software to remove badsectors??
i used HDD Regenerator it asks for floppy ....& I dont have floppy drive...so suggest me som windows based software .....
Thanx.........
pushkar1986 is offline
Old 05-08-2006, 01:19 AM   #2 (permalink)
El mooooo
eddie's Avatar
Default Re: hdd badsectors removal...without use of floppy...:P
If you have HDD Regenerator then it also works with CDs. Just pop a blank one in your burner and burn a CD. I have never come across any Windows based Hard disk regenerators and even if you get one...it will most probably be useless. Removing bad sectors needs exclusive access to HDD and I doubt that a Windows based application will be able to get that kind of access.
eddie is offline
- by c4u
