Old 04-08-2006, 01:42 PM   #1 (permalink)
evil_maverick's Avatar
Default cranked up fsb?will it damage my sys?
hey ppl!!
my config--
mobo-msi k8ngm2il
pro--amd 64 3200+ 939 pin venice core
512 megs
80 gb hdd
i cranked my fsb to 240 (default is 200.9)
will it damage my system?
the system is wrking fine!!
plz advice
In the pocket - Samsung Wave S8500 : Bada 1.2
In the Bag - HP DV6-6017TX
At home - Samsung 20'' Since 2001 :D :-P
evil_maverick is offline
Old 04-08-2006, 01:55 PM   #2 (permalink)
-The BlacKCoaT Operative-
Rollercoaster's Avatar
Default Re: cranked up fsb?will it damage my sys?
nah 240 is kool
what is the multiplier? i guess 10. so ur new CPU speed should be 2.4Ghz
i have a64 3000+ default fsb=200, Multi is 9x. i have it OCed to 289 fsb x 9= 2.6GHZ that too on stock cooling.... max temp 59 normal 48...
Rollercoaster is offline
Old 04-08-2006, 02:11 PM   #3 (permalink)
samrulez's Avatar
First check what is the memory speed.....coz when the base clock in increased all clock on the mobo will increase........
Have u locked the PCI/AGP....33/66
Make sure the southbridge is locked also.....
Also..as i said....the memory speed will also increase....so not only u r processor is overclocked but u r memory is too!!
And to check stability use Prime95 ''Torture Test''
Just speed is not everything.....so run some benchs at stock and at oc...then u willl come to know how much performance did u gain,.....
But i have a doubt about the performance increase..coz u r memory may be the bottleneck
Sam :D Rulez :lol:
samrulez is offline
Old 04-08-2006, 02:22 PM   #4 (permalink)
1) You have oced your machine. Do you even know what it is? If you have the right hardware and do ocing with care and all proper measures most of the time, practically almost all the time nothing goes wrong. But if you don't keep these things in mind you can destroy your pc and warranty.
2)OC destroys warranty, to get warranty you need to reduce it to stock settings, bios default then get the RMA.
3)Your cpu should be ok for oc. Don't know of mobo, what ram modules do you have? What power supply do you have?
4)Who did the oc?
5)Does your mobo have pci e, pci etc locks.
6)What else did you change?
7)Run:
Super Pi 1M test
Super Pi 32M test
Prime 95, 12hrs continous stress test
If you comp passes all this without any errors and all then there is no problem. Else there can be.
akshayt is offline
Old 04-08-2006, 03:15 PM   #5 (permalink)
the sys is booting up.....nicely...
and the memory is running at 240 mhz(default 200 mhz)
and how do i run these tests like Super Pi 1M test etc?
even though my sys is booting up nicely does it still mean that it might get sum probs coz of the co??
yeah 1 more thing..
the nbridge and sbridge frequencies r set to 1000 mhz
Old 04-08-2006, 07:02 PM   #6 (permalink)
samrulez's Avatar
I don't think u r memory will be able to handle 240 MHz i.e 480 MHz unless it is UCC chips ....Bring the speed down and then go again starting from 333MHz.....or u will fry them...
Download Prime 95 and select Torture test and let it run for a few hrs...And keep monitoring the temps...
the nbridge frequencies r set to 1000 mhz
The Athlon 64 s don't have a northbridge.....
Also...the procey u have can run at 2.8-2.9GHz if u have good memory....
Sam :D Rulez :lol:
samrulez is offline
Old 04-08-2006, 08:34 PM   #7 (permalink)
......well......i hv been using my sys for long hrs with the cranked up fsb.....the temp is staying normal......and everythin seems ok.....but is there still a danger that i may fry my ram???
Old 04-08-2006, 10:29 PM   #8 (permalink)
Google Bot
Pathik's Avatar
if the temperature is normal then no problem.......
u r safe....
Pathik is offline
Old 04-08-2006, 10:35 PM   #9 (permalink)
samrulez's Avatar
If u want to overclock do it the right way!!!
First lock the PCI bus.....
Then set the memory clock to 333MHz and then start increasing the FSB...at every 20MHz check for stability,,,and also keep checking the ram clock a oc of 10MHz is ok for cheap ram but not 80MHz!!
Which ram do u have??
Also I don't think u r getting max out of u r processor even at stock speed coz the memory is the bottleneck...
Sam :D Rulez :lol:
samrulez is offline
Old 04-08-2006, 11:21 PM   #10 (permalink)
hey sam......
i did it.......
u may say am a lil careless....but.....
i cranked the fsb to 240!!
(u may say am stupid!!)
the cpu frequency went upto 2.4 ghz...
the ram frequency went to 240 mhz.....
everything is stable.....i am wrkin on my sys for 4 hrs at a stretch now,the temp is fine....around 37-44 celcius......
and am using zion ram(abacus php)....
thats it.....
so what do u say?
is it risky?
should i keep it like this or not?
n i more thing usaid that my memory is the bottle neck....so should i add 1 more 512 stick?
Old 05-08-2006, 12:44 AM   #11 (permalink)
very risky, you could have damaged your system.
Read some amd 64 oc guides.
Also ,download super pi, run 1M test and 32M test. Then run 12hr+ of prime 95 stress test and memtest for about 10-12hrs.
If all is well, then you should be well, have a look at temps that time
memory bottleneck doesn't mean size here. Anyway reduce your ram speed to 333 and you should be able to do 2.6 or so provided you have right cooling, cpu, psu etc
akshayt is offline
Old 05-08-2006, 03:05 AM   #12 (permalink)
deathvirus_me's Avatar
Well .. if ur system is stable then u need not worry ... i cranked up my FSB to 300 once ...
deathvirus_me is offline
Old 05-08-2006, 03:20 AM   #13 (permalink)
CG Artist
gaurav_indian's Avatar
Plz can any one explain to me what exactly is overclocking?And what role do southbridge and northbridge play?
gaurav_indian is offline
Old 05-08-2006, 10:57 AM   #14 (permalink)
samrulez's Avatar
Overclocking nothing but over-volting or increasing the power..........
The southbridge is the chip on the mobo than controller the SATA\PATA......the nothbridge is not included in the athon64 system.....
@evil_maverick :I don't think zion will be able to handle 480MHz....so what I suggest is that....
Restore the FSB to 200MHz.....then bring down the clock to 333MHz/266MHz.....then again increase the FSB.....so the memory clock wiill be near 400MHz and not 480MHz.......that wiil be a safe oc..
To check the stability normal use is not enough ,....
Downlad Prime 95 from http://www.mersenne.org/freesoft.htm
And torture test u r system for a few hrs.....
Also adding another 512MB stick would be a great idea.....so do it get it..........if u can ....
Make sure u have locked the PCI at 33MHz....and PCIe also ...
Sam :D Rulez :lol:
samrulez is offline
Old 05-08-2006, 06:20 PM   #15 (permalink)
thanx ppl!!
and can u suggest what brand of ram shud i get?
i guess corsair wud be great!!
but how much more do i need to shell out for a corsair 512 stick??
Old 05-08-2006, 06:26 PM   #16 (permalink)
samrulez's Avatar
No use adding another Corsair module.....U will have to get 2 Corsair modules.....
For corsair Value Select 512X2 kit costs about 5k......
Sell the old Zion module ans get a new Corsair Value Select kit
But if u r on a tight budget then get Transcend Ram with Samsung UCCC chips or Hynix D43 chips....they R highly overclockeble....
Sam :D Rulez :lol:
samrulez is offline
Old 05-08-2006, 06:56 PM   #17 (permalink)
Well ... at stock latencies Hynix modules can do around 450 easily ...
Old 05-08-2006, 06:58 PM   #18 (permalink)
corsair value select might not be that expensive.
please see your mobo manuals.
ram : 333
cpu, increment in 5mhz to fsb until it doesn't boot. Then increase your voltage by 0.0125 or 0.025. Try again. Make sure you have proper cooling and try to remain under full prime 95 load under 60C, preferably under 55C.
Try with multiplier 9x as well. Read oc guides.
If possible don't give a v core of more than 1.5, but again there are people who may even give 1.6-1.7, it might not be that saef though with any cooling maybe.
Anyway, for serious oc, get better cooling, a branded and good one
akshayt is offline
Old 05-08-2006, 11:11 PM   #19 (permalink)
ram : 333
If possible don't give a temp of more than 1.5, but again there are people who may even give 1.6-1.7, it might not be that saef though with any cooling maybe.
You meant V core?
V.Prem Kumar
janitha is offline
Old 06-08-2006, 12:04 AM   #20 (permalink)
yes, vcore
akshayt is offline
Old 06-08-2006, 10:21 AM   #21 (permalink)
hmmmm......
isnt the multiplier of amd 64 processors fixed(except the fx series)?
and i cant change the v core voltage .....there is no option.....
can jus increase ram voltage and crank up fsb dats all.....
Old 06-08-2006, 10:54 AM   #22 (permalink)
multplier can bereduced not increased for amd 64. I think don't use mulipliers as 8.5,9.5, don't use them, atleast not until an expert approves.
Without v core change you may not be able to go very high, look for that option, otherwise change the mobo for higher ocs, get dfi.
akshayt is offline
Old 06-08-2006, 09:14 PM   #23 (permalink)
today ran prime 95....
it ran 4 almost 2 hrs (stress test)..
and no errs occurred......
so .....
can i inc my fsb now safely?and how much?
Old 06-08-2006, 09:17 PM   #24 (permalink)
samrulez's Avatar
It at at oc or at stock???FSB??
Sam :D Rulez :lol:
samrulez is offline
Old 06-08-2006, 10:19 PM   #25 (permalink)
If you really want to be safe:
Run Super PI 32M test
Run Super Pi 1M test only for quick checks, but do the 32M test after you have decided to keep a speed, try the 32M test for sure.
Run 3d mark 06, 05 and 01
3d mark is very very intensive, my prime 95 torture test using 1024(though you keep everything default, was a mistake by me) small FFTs for 8hrs showed no error, it failed 3d mark 06 and 05 in minutes.
Run Prime 95 for 8-12hrs atleast. Preferably 24hrs or more.
If you have oced your ram then run memtest around 10hrs or so.
After that you are fine.
akshayt is offline
Old 07-08-2006, 07:39 AM   #26 (permalink)
Noop .. all Athlon64 models are multiplier unlocked ... but the normal Athlon64 multiplier can only be lowered below the max. value according to the processor .. while the FX series can go both ways ...
- by c4u
