Old 04-08-2006, 04:08 AM   #1 (permalink)
Unhappy My Sata HDD Beeps
I have a strange issue with the sata hdd that i bought recently. i formatted it installed windows xp. it worked fine for a week and after that it started beeping. i got it replaced.
the replaced hdd also worked fine for 2 days and again it started beeping. Seagate replaced my 120GB Sata drive with 160 GB today. the drive use to beep again. but after restarting it two or three times it works again.
My system config goes like this:
P4 3 Ghz
Intel 101GCC2 motherboard
512 MB DDR2
160 GB HDD
DVD RW Asus
DVD ROM Sony
plz help me guys really worried for the HDD
'Veni, Vidi, Velcro\' - I came, I saw, I stuck around.
hyde is offline
Old 04-08-2006, 01:53 PM   #2 (permalink)
-The BlacKCoaT Operative-
Rollercoaster's Avatar
Default Re: My Sata HDD Beeps
are u sure it is the drive beeping.. must be the mobo's speaker..
bTW it could be due to bad SMPS.. get a new one or get it checked...
Rollercoaster is offline
Old 04-08-2006, 11:02 PM   #3 (permalink)
thetopcyborg's Avatar
hey, my PATA one also beeps, its Seagate barracuda 7200rpm, and it produces a clicking sound too, and sometimes my win2000 shows an error that boot device unaccessible, but it corrects after sometime, and recently the access to explorer and data has also been slowed down, and i want to ask one question, in the IDE 80 conductor of the PATA Hdd, is there a 1mm2(1 millimetre square area) of wire that is not present at all? as there is a kind of 1mm width 'hole' in my cable
thetopcyborg is offline
Old 05-08-2006, 11:55 AM   #4 (permalink)
The Thread Killer >:)
phreak0ut's Avatar
This means the disk if failing. BACK UP NOW!!!! You will have to take it to the data recovery center if the disk fails completely. BACK UP NOW!!!!!!!!!
phreak0ut is offline
Old 05-08-2006, 04:32 PM   #5 (permalink)
P4 3 Ghz
512 MB DDR2
160 GB HDD
DVD RW Asus
DVD ROM Sony
tried using new sata cables?
Sand man is offline
Old 06-08-2006, 02:12 PM   #6 (permalink)
thanx for the replies....
when my hdd beeps what i do is turn off the power and just reseat the power and data cable. and boot the system it works fine. but sometimes while doing some work it beeps. and then windows freezes....
i am worried is my motherboard bad. cos i got my hdd replaced twice
hyde is offline
Old 06-08-2006, 02:21 PM   #7 (permalink)
yogi7272's Avatar
seagate sata drives have probs .. i have had lots of them ..
now i have changed my psu to cooler master one .. lets see .. if psu was the prob ..
same probs as u .. i have faced .. changed data cords .. power cords .. now i changed my psu ..
back up ur data now.. it can fail any time..
seagate should do something abt it .. definetly some prob with their sata hdds ..
yogi7272 is offline
Old 06-08-2006, 09:01 PM   #8 (permalink)
Geforce's Avatar
BINGO !!
I have the same problem, system works fine for 2-3 weeks but then my seagate 200gb hdd beeps and the system freezes, but i HAVE found where the problem is.
Its the SATA cable.
Fistly, the SATA cable we get are not insulated and sata signals get lost very easily with electromagnetic external disturbances within the system.
If there is a slight kink (90 degree turn) in the cable it has high chances of signal loss (found all this after visiting several forums) and SATA drives unlike PATA drives don't replenish (from corrupt data signal) themselves without a system restart .
Make it as straight as possible. Currently i have done so.
Getting a high quality insulated SATA cable will completely erase the problem, i m pretty sure.
AMD Athlon64 2800+, MSI K8N Neo3(NForce4), 1GB Kingston DDR400, MSI Geforce 7600GT PCIe, Viewsonic VA702b 17" LCD, Creative SB Live! 5.1, Logitech Z-5300 5.1 THX Speakers, Seagate 200GB SATA HDD
Geforce is offline
Old 06-08-2006, 09:41 PM   #9 (permalink)
yogi7272's Avatar
Originally Posted by Geforce
BINGO !!
Its the SATA cable.
and why then other hdds dont have same problem as seagate .. i have used wd , maxtor , hitachi as well as samsung .. same capacity .. same sata 2 interface drives in the same position with the same data and power cable with the same psu .. and guess what ..
they dont have any prob with it ..
why then only seagate hdds keep beeping .. is a question to me ..
yogi7272 is offline
Old 07-08-2006, 11:56 AM   #10 (permalink)
Unless you use right angled SATA cables
check this page for the right angled SATA cables....
http://www.satasite.com/sata-cables-....htm#one-right
Anyone come across right angled cables anywhere in India ??
suman2005 is offline
Old 08-08-2006, 12:55 AM   #11 (permalink)
Geforce's Avatar
I am talking about a kink in the cable not the connector. So basically this twist is not that we want.
Regarding the SATA cable, do you have any idea about insulated SATA cables ?
Geforce is offline
Old 09-08-2006, 11:31 AM   #12 (permalink)
thanx for the replies will let you know after i get some good sata cables and a PSU.... thanx again to all of you guys
hyde is offline
Old 10-08-2006, 01:52 PM   #13 (permalink)
and can plz anybody tell me where can i get high quality SATA cables ... which will not lead to signal loss.... anyways i am going to try my pc with 500 watt PSU....
hyde is offline
Old 10-08-2006, 03:26 PM   #14 (permalink)
i am still unable to understand how a drive "Beeps".
i have seen the insides of a lot of drives and there is nothing there to make electronic sound. only mechenical sounds can come from a HDD.
are u sure it is a BEEP not a SCREECH sound.
Old 10-08-2006, 07:06 PM   #15 (permalink)
yogi7272's Avatar
Talking Re: My Sata HDD Beeps
dont worry..
if u have seagate hdd .. then u will soon know .. whether its electronic or mechanical ..
yogi7272 is offline
Old 10-08-2006, 07:19 PM   #16 (permalink)
i have been using seagate for the past 14years.... from the time they had 640MB as mainstream hdd. btu never heard of BEEPS
Old 11-08-2006, 02:21 PM   #17 (permalink)
yogi7272's Avatar
buddy , i have used 15 seagate pata drives before this .. never had any single problem ..
i am saying this cos i had lots of prob with seagate .. and not a single one with any other sata drive .. even go check some forums .. seems like seagate failour rate is big.. with their sata drives ..
yogi7272 is offline
Old 12-08-2006, 12:56 PM   #18 (permalink)
plz let me know guys where to buy high quality SATA cables???
hyde is offline
Old 16-08-2006, 07:29 AM   #19 (permalink)
hey GUYS .... a new SATA cable solved the ISSUE......
thanx for the help guys
hyde is offline
Old 16-08-2006, 10:47 AM   #20 (permalink)
gooby pls
Third Eye's Avatar
I don't heard that HDD beeps.
are you sure HDD beep,maybe the mobo or processor beeps.try ears contact with HDD.
Third Eye is online now
Old 17-08-2006, 08:44 AM   #21 (permalink)
yogi7272's Avatar
buddy u will know when ur seagate hdd will start doing that ..
yogi7272 is offline
Old 17-08-2006, 10:19 AM   #22 (permalink)
gooby pls
Third Eye's Avatar
Angry Re: My Sata HDD Beeps
Never ! It's your other mobo component which is doing this thing.
Old 17-08-2006, 10:37 AM   #23 (permalink)
yogi7272's Avatar
r u a seagate employee ...!
yogi7272 is offline
Old 17-08-2006, 11:31 AM   #24 (permalink)
trust me it is the SATA drive that was making the noise you can even try with ur sata drive just remove the sata cable and power on the system and the HDD will beep
hyde is offline
Old 28-08-2006, 11:51 PM   #25 (permalink)
Geforce's Avatar
@Hyde have your problems with SATA HDD vanished. Now i am facing this issue (beeps and system freeze) again with my SATA seagate 200gb. Since the last post in this thread i had assumed the problem was resolved by new SATA cable but it hasn't.
This time i had bought a high quality SATA cable, but it hasn't worked, i even have a new MOBO now (nforce4) so i guess it really is a problem with
Seagate HDDs.
I don't quite know how they will even RMA it, as this problem i not easy to reproduce. What should i do ?
Geforce is offline
- by c4u
