Re: Best Laptop/Desktop
For any budget, a desktop beats a laptop in gaming performance and for that matter maybe any performance.
Amd 64 3000/3200/3500 Venice : 4500/5200/5700
It might be a better idea to get Amd 64 3000 and better cooling from antec, thermaltake or whoever makes good/decent stuff in your budget and oc your cpu to 2.6-2.8. Anyway, you should be able to get 2.5-2.6 or so or maybe higher but better cooling is recommended.
Asus A8N E : >5k
2 X 512mb DDR 400 Transcend ram using samsung uccc chips, this will be written on the modules, if you don't get these ones then get transcend modules using hynix d43 chips instead.
around 4k
Seagate SATA II NCQ 250-300: around 4k or more, 300 maybe around 4800 or so
Local cabinet + a not so great but no exactly generic psu, pm me for details here, keep aside around 2500 for here
17"/15" monitor crt,
17":Samsung 798MB PLUS or better, around 6k
ok for a res of 10X7 or higher and if your budget doesn't compromise on gpu etc.
15"
samsung or any other company if it is better
better for playing at 800*600 or lower which you may soon/currently need to if you don't upgrade regualarly.
around 4k or so or maybe less i think
this also gets more money for gpu etc and is better if you have to game at 8X6 or lower else you will see lines and all.
microsoft comfort mouse 3000 + microsoft internet/multimedia keyboard, around 1500 together
consider iball precise 1600dpi or something around 600, although it prefer microsoft and logitech
dvd rw
combo
around 4k+ together
microtek 800va around 2000+, sub 2500
fdd :around 200-300
altec lansing 2.1 : around 1500 or if you want altec lansing 251 (5.1) around sub 4k or another 5.1 around 3500 or a 2.1 atp 3 around 3-3.5k.
GPU
1)Geforce 7600GT/X1800GTO : >10k
2)Geforce 6800GS 256mb : around 10k or might be lower
3)Geforce 7600GS : around 7k
4)Geforce 7300GT GDDR 3 : if available might be around 5-6k or so
5)Not sure between Geforce 7300GT DDR2 and 6600GT, but 6600GT may be better, 7300GT DDR 2 : around 4.5k or so and 6600GT may be around 6.5k or so
Branded comp will never be as good
