Old 01-08-2006, 10:26 PM   #1 (permalink)
Smile Broadband Modem: One USB port to Two USB port
I am using BSNL broadband with ASDL modem . This modem has one USB port, to connect to computer.
It is possible to make this one port into two USb port using some extension so that I can connect this to two computer? Will it work?
ajinkyakulkarni87 is offline
Old 01-08-2006, 10:39 PM   #2 (permalink)
Venom's Avatar
Default Re: Broadband Modem: One USB port to Two USB port
You can do this. Connect your internet to one comp. Use a USB cable with a hublink and connect your two computers like a network and then share your connection between the two.
Venom is offline
Old 02-08-2006, 10:09 PM   #3 (permalink)
But can I do it directly through modem and not sharing Internet connection between two computer. That means can i use any connector which will connect one USB port to two USB port of different computers simultaneously to use internet connection.
I want to access internet connection independent of other computer and with only one modem and one telephone line of BSNL Broadband
Old 03-08-2006, 09:56 AM   #4 (permalink)
-The BlacKCoaT Operative-
Rollercoaster's Avatar
i dont think that is possible as that usb port is a LAN port...
Rollercoaster is offline
- by c4u
