Old 01-08-2006, 08:51 PM   #1 (permalink)
Default laptop problem
i've acer 4060 travelmate notebook. it was working fine until yesterday.
but this morning when i pressed the power button nothing happened.
the computer doesn't not turn on.
i've tried all the troubleshooting tips given in acer user guide but all in vain.
the battery is fully charged.
any help?
Shasta is offline
Old 01-08-2006, 09:44 PM   #2 (permalink)
Default Re: laptop problem
this thing happened with me once .... the problem was that battery was loose ....try taking it out and then back again.....u will be able to do it...hope it helps
blacklisted is offline
Old 01-08-2006, 09:44 PM   #3 (permalink)
Venom's Avatar
What'd you do last with it ?
Ofcourse, there is always the laptop service center for all these problems, use your Warranty/Guarantee (whatever...)
Venom is offline
Old 01-08-2006, 10:17 PM   #4 (permalink)
well the computer has now turned on. but every time during the boot
it beeps and gives the following error message
Resource Conflict - PCI Network Controller on Motherboard
Bus : 06, Device : 04, Function : 00
what does it mean
can i do something about it.
Shasta is offline
Old 01-08-2006, 10:25 PM   #5 (permalink)
Laptoping
Sourabh's Avatar
Take the laptop to the service center and get it checked out.
Sourabh is offline
- by c4u
