Old 31-07-2006, 11:04 PM   #1 (permalink)
Nee po mona dinesha!
Default Vista ready !!
First of all here is my System specifications:
AMD Athlon XP 2400+,
2.01 GHz CPU, 40 GB HDD,
LG DVD-RW, VIA/S3 Unichrome video card,
VIA KN400/KM 400 Chipset
and running Windows Vista Build 5472
My video card dont have support on "Aero". And i need a grapics card which supports Aero. I need that gfx card only for aero and i dont play games or any other activites. I think my PC only supports AGP Cards. So please suggest a good Aero supported AGP grapics card for my PC.
Sreeejith is offline
Old 31-07-2006, 11:34 PM   #2 (permalink)
rahul_becks23's Avatar
Default Re: Vista ready !!
get a 7300 GS.........its the latest budget solution.
rahul_becks23 is offline
Old 01-08-2006, 08:37 AM   #3 (permalink)
You know the price of that card ?
My Gallery: http://sreeejith.deviantart.com
My site: http://www.sreejithlive.info
Old 01-08-2006, 06:40 PM   #4 (permalink)
dunno abt GS but GT is av. for 5 and a half grands.
so,GS maybe ar. 4 grands.
Old 01-08-2006, 06:44 PM   #5 (permalink)
samrulez's Avatar
But 7300GS is a PCIe card.....its not available in AGP...
To run aero all u need is a 6200 or higher..
So get any card above 6200 .....
Sam :D Rulez :lol:
samrulez is offline
Old 01-08-2006, 08:14 PM   #6 (permalink)
gxsaurav
Posts: n/a
who said u need a geforce 200 at the minimum
graphics card above Geforce FX 5200 or Radeon 9600 can run vista at max quality
6200 is a good choice, cheap & best
Old 01-08-2006, 09:36 PM   #7 (permalink)
do you have 1gb ram?
also your cpu is too slow.
akshayt is offline
Old 01-08-2006, 10:14 PM   #8 (permalink)
samrulez's Avatar
I don't think Athlon Xp 2400+ is slow for vista.....dude its more than enough!!
Sam :D Rulez :lol:
samrulez is offline
Old 01-08-2006, 11:08 PM   #9 (permalink)
improve hdd(80gb) and ram till till 1 gb(min 512mb will do)....also u need good graphic card
magnet is offline
Old 02-08-2006, 03:32 AM   #10 (permalink)
deathvirus_me's Avatar
Well .. if u only want Aero and have no intention of gaming what-so-ever .. then get a FX 5200 .. should costs around 2k's ...
Even at times i think my 3800+ ( oc'ed 3500+) is struggling a bit ... i really suggest that for Vista u really should opt for a dual core .. but not everybody is that rich (inc. me) ...
deathvirus_me is offline
Old 03-08-2006, 10:44 PM   #11 (permalink)
Dink2cool's Avatar
hey Sreeejith ... do u have an asus mobo ... coz if u do then u n i have the same mobo ... lemme tell u then that the mobo has 4X AGP slot .... and $X is not fast enough to support Vista ...
Kamehameha !!!!
My blog : dinkarpundir.blogspot.com
The guy who invented the first wheel was an idiot; the guy who invented the other three, he was the genius.
Dink2cool is offline
- by c4u
