Vishal, I love you man! Thank you for your suggestion. I tried your suggestion, it didn't workout as expected and then you know what I did? I tried Add/Remove Hardware. And then manually installed the driver. Maybe this is how it should have been done, but I didn't have any manual...
Here is what I did :
I had a CD which had an exe to install MP3 Player Utilities. I thought that if I installed the software, the driver would be installed automatically. So restarted the computer. Nothing hapened. Then I used Add/Remove Hardware and specified the driver file manually and that was where I had gone wrong.
Now, am so happy man!!!
Hey Fighter, I have an old system with 128MB RAM(Pentium III 800MHz) and am not going to upgrade my PC in near future till my son breaks it in to pieces
And then I'll buy a brand new one with the latest config
Thanks buddies for your inputs.
