Originally Posted by Eazy
MAX size for Laptop HDD available in Mumbai in attached Ad is a Seagate 160GB.... I have never bought from these people so dont know how they are to deal with....
Thank u so much for that info...but i am from kolkata...anyways thanks a lot it gives some idea...
"Moreover, you also need to be careful with their type. The newew 2.5" drives are based on SATA and you have a ATA-100 hdd controller. "
does it mean that my acer laptop 3212 cannot accommodate SATA hard disks which are of larger size....?????
" I think it is good enough, anything over 100GB is an overkill. "
I am planning install sap application on hard disk and use it to boot it...so ext hard disk will not serve the purpose as we cannot boot from ext hard disk...
thanks for ur replies... plz clarify above two queries...
