Old 29-07-2006, 12:27 PM   #1 (permalink)
Default problem with Pen Drive
everytime i plugin the 4GB Sandisk Pen Drive in my lappy's USB slot i get the Removable Disk drive(K in My Computer but when i try n open it ...it says insert a disk in drive K: ....but yesterday it was working fine....this error started when i wrote some more data to it...
blacklisted is offline
Old 06-08-2006, 01:20 AM   #2 (permalink)
Default Re: problem with Pen Drive
anyone?? plz its really imp
Old 06-08-2006, 03:31 AM   #3 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
Try to format the Pen drive!
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 06-08-2006, 08:36 AM   #4 (permalink)
deathvirus_me's Avatar
Did u try to format the drive ???
deathvirus_me is offline
Old 06-08-2006, 05:53 PM   #5 (permalink)
the problem is that i cant even format it ....it says no disk in drive.....also in disk management it recognises that there is a removable media but sshows no partitions and neither allows me to create a new partition . i tried partition magic too but the drive doesnt even show in there .
Old 14-08-2006, 05:37 PM   #6 (permalink)
i'm having the same problem blacklisted has please help me
kokal is offline
Old 24-08-2006, 12:16 PM   #7 (permalink)
Exclamation Re: problem with Pen Drive
cspandey41 is offline
Old 24-08-2006, 12:17 PM   #8 (permalink)
Try on some other machine, if works there then some issue with your machine or the pendrive has probs.
www.Solinweb.net - Webhosting was never so cheap in India!
www.cyclone2k.net - More than wrestling....
www.myspacery.com - Myspace Layouts, Myspace Codes, Myspace Generators, Myspace Tweaks
thecyclone2k is offline
Old 06-10-2008, 03:12 PM   #9 (permalink)
Unhappy Re: problem with Pen Drive
somebody please help..i am also having thesame prob wid my 4 gb iball pd...
ishmeet_baby@yahoo.co.in is offline
Old 14-07-2009, 01:37 AM   #10 (permalink)
I would suggest formatting it on a different system. Also try formatting through command prompt with format command if it works. If it is not possible,
First run a disk check on it using chkdsk command. It will fix file system errors and you'd be able to format it fine then.
techsniper is offline
Old 30-10-2009, 04:35 PM   #11 (permalink)
How Do I Create A partition On A pen Drive ?
Digito is offline
- by c4u
