Old 28-07-2006, 10:47 AM   #1 (permalink)
Default upgrading RAM query
Hi
I have SIS 630/730 motherboard, 128 MB RAM, AMD Athlon 1.2 GHz its 6 yr old PC. I want to upgrade RAM up to 512 MB.
I asked vendor about upgrading and he told me that “your motherboard doesn’t support more the 128MB RAM, Bus speed is low, you need to change motherboard for this”.
I am not tech guy. can anyone suggest me.
Do I really need to change Motherboard? or upgrading will work?
thanks.
kamblemilind is offline
Old 28-07-2006, 10:51 AM   #2 (permalink)
Google Bot
Pathik's Avatar
Default Re: upgrading RAM query
wats the speed of ur 128mb ram.... cant be less than 266mhz
Pathik is offline
Old 28-07-2006, 01:05 PM   #3 (permalink)
Core i7 (nehalem) Owner
ashu888ashu888's Avatar
It would be better if u had ur motherboard manual with u so tat u can refer to wat the maximum RAM it can support, else u can search on the manufacturer's website for the same.
I guess, ur mobo (motherboard) is an old one but according to my opinion, it shud be able to support atleast another RAM module (stick) of 128 MB making it a respectable total of 256 MB. But however, its better to refer to the manual/ documentation so tat even u can hv a clear idea (rather than the tech guy foolin' u)...
See this for ur reference....
www.answers.com/topic/sis-630-730
Cheers n e-peace....
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
ashu888ashu888 is offline
Old 28-07-2006, 02:18 PM   #4 (permalink)
thanks ashu.
Old 28-07-2006, 02:51 PM   #5 (permalink)
try a 256mb module and check it up yourself or download manual or read it up from the website if there is one over there.
akshayt is offline
- by c4u
