Old 27-07-2006, 07:41 PM   #1 (permalink)
Default my pc only beeps; does not boot......heeeelp
plz help
my pc after turning on just beeps for some time ; stops; again beeps . there is no display, nothing . plz help me to solve this problem; i cant live without my pc
my config:
via 845 chipset
128 mb ram
1.8 ghz P4
40 gb hdd
win xp
Omsck is offline
Old 27-07-2006, 08:42 PM   #2 (permalink)
Stalker's Avatar
Default Re: my pc only beeps; does not boot......heeeelp
hey, first check ur monitor cable, make sure u have attached it firmly to its socket.
then, try removing & reseating ur RAM
do u use a agp card or onboard video.........??
AWARD BIOS BEEP CODES
1 long, 2 short - Indicates a video error has occurred and the BIOS cannot initialize the video screen to display any additional information
Any other beep(s) RAM problem.
Alternating high & low (tones) beeps - CPU problem ........try removing & reseating ur processor
| C2Q Q6600 G0 | Intel DG33FB | 4 GB Corsair 6400C5G DDR2-800Mhz | XFX 8800GTX | CM Extremepower 600W | 250GB Seagate HDD | Lite-ON 1635S DVD RW | Logitech MX-518 | Zalman RS6F | APC RS 800 |
Stalker is offline
Old 27-07-2006, 08:42 PM   #3 (permalink)
sknowonweb's Avatar
Unlock CPU Cover.
Clean Dust in Processor and RAM . (There must be Dust !! for this type of problm )
This should solve problem.
தமிழ் வாழ்க
____________
EVIL : G00D :: YIN : YANG
________
sknowonweb is offline
Old 27-07-2006, 08:44 PM   #4 (permalink)
Stalker's Avatar
Also make sure than all PCI components are firmly attached
if u use a graphic card try removing & reseating it. Also remove any dust on the components (if any) ........as dust sometimes can prevent electrical connections
Stalker is offline
Old 27-07-2006, 08:47 PM   #5 (permalink)
Google Bot
Pathik's Avatar
1st of all check that ur power button wires r properly connected....
Pathik is offline
Old 27-07-2006, 11:51 PM   #6 (permalink)
the deconstructionist's Avatar
Must be a defective RAM strip.
Welcome to the desert of the Real...
" ಡ್. ರಾಜ ಅಭಿಮಾನಿ "
the deconstructionist is offline
Old 27-07-2006, 11:52 PM   #7 (permalink)
HELP AND SUPPORT
rakeshishere's Avatar
Replace ur CMOS battery with a new one
rakeshishere is offline
Old 28-07-2006, 10:30 AM   #8 (permalink)
ayush_chh's Avatar
i dont think when the CMOS battery is discharged the PC beeps.
u can press F1 and continue.....
@ Omsck
go thru DIGIT's FAST TRACK u will find the explanation for all the beep codes...
ayush_chh is offline
Old 28-07-2006, 11:33 AM   #9 (permalink)
first the person havent replied.......
and the beep problem 75% of time is loose ram related problem......and i guess its the same....... check that ........
magnet is offline
Old 28-07-2006, 11:38 AM   #10 (permalink)
Google Bot
Pathik's Avatar
i think magnet is correct.....
Pathik is offline
- by c4u
