Old 26-07-2006, 09:38 PM   #1 (permalink)
shyamno's Avatar
Question URGENT!!!CD ROM is missing
I can not find my CD ROM drives in My Computer.It was there but now it's gone.
Please help me.
I am having dual Boot,in XP it is not present but but in Win 98 it is well present there and it can also read from CD.
shyamno is offline
Old 26-07-2006, 10:08 PM   #2 (permalink)
gooby pls
Third Eye's Avatar
Default Re: URGENT!!!CD ROM is missing
Check that CD-ROM is properly fit with wires in mobo also open device manager and click action tab and choose "Scan for hardware changes" this will install lost CD-ROM Drivers.
Tell me if this helps you !
Third Eye is online now
Old 27-07-2006, 02:57 AM   #3 (permalink)
deathvirus_me's Avatar
Well ... something messed up the driver inf file in XP ... maybe something 98 did ... u can try to manually add the CDROM and check ..
Also .. i'd prefer u to get a firmware update for the CDROM .. as it sounds it might be quite old ...
deathvirus_me is offline
- by c4u
