Re: How to accomodate 723 MB in 700 MB CD
Yes .. right as kalpik said ..just burn it in vcd mode only.
otherwise it wont play in vcd player
dat files are of larger size .. wen u use vcdgear to convert it to .mpg .. its get reduced a little.
dat files are raw files .. so that they can be read at vcd players
even more than 730MB dat files can be fit on CD-R sometimes in vcd mode
n
For DATA CD --> You can burn upto 722 mb in Overburn .. but u should choose disc at once
