Old 23-07-2006, 12:29 PM   #1 (permalink)
Default DVD-RW query
Hey Everyone,
Now that I got 700mb left in my 80gb hdd I finally need to buy a DVD-RW. But, since following hardware market for a while can somebody, please help me with DVD-RW purchase. Here are my queries -
1. I need support for Dual Layer DVD-RWs. Are there 2 types of DVD burners?? One for dual and single, and other just for single??
2. What brand/ model in your opinion are nice? My budget is 4-5k, I would prefer internal one.
3. Can any DVD-RW be able to write and read any type of DVD? DVD+R, +RW, etc??
3. Any other suggestion/ tip?
Thanks.
www.Solinweb.net - Webhosting was never so cheap in India!
www.cyclone2k.net - More than wrestling....
www.myspacery.com - Myspace Layouts, Myspace Codes, Myspace Generators, Myspace Tweaks
thecyclone2k is offline
Old 23-07-2006, 01:35 PM   #2 (permalink)
go_gamez's Avatar
Default Re: DVD-RW query
u have a budget..which i dont think is needed even for a dual layer dvd burner...
u can get a sony dvd dual layerwriter..820 -A for less than Rs. 2700 .and it is one of the best dvd writer....it can write both single and dual layer dvds..u buy this and use rest of u r budget to buy dual layer dvds which r quiet expensive..
Intel P4 2.47 ghz with 1 MB L2 cache-HIS 845GVM mobo
512 MB DDR RAM .
Gainward 6600 gt golden sample edition(ultra 1960xp)
80 GB Seagate Barracuda 7200 rpm HDD
Sony QW -120A Dual Layer DVD writer.
go_gamez is offline
Old 24-07-2006, 12:34 PM   #3 (permalink)
tuxfan's Avatar
I will support that! You can go for a Sony. They are nice BTW, dual layered media (blank DVD-R) is still not too cheap and is not too easily available at least here in Lamington Road.
Yes, there are 2 types of burners and 2 types of media as well.
Even you take an internal writer, you can use an IDE to USB convertor for about Rs. 700-800 and use that one as an external one.
tuxfan is offline
Old 25-07-2006, 11:37 AM   #4 (permalink)
Thanks for the info. But, my hardware guy says to go for HP as they are their authorised service people here. Any comments on hp??
Then, what is the fastest DVD-Writer at the moment?? and it's speed?
And, will dual layer writer be able to burn single layer too??
I don't wanna upgrade again in 1-2 years so, I am thinking for a long term perspective. So, dual layer writer should be better ain't it??
Also, what is the current prices of blank dual layer and single layer discs??
Old 25-07-2006, 02:20 PM   #5 (permalink)
papai_mcc's Avatar
go for liteon aqua series.
View My Photo Gallery: http://the3rdeye.co.cc
papai_mcc is offline
Old 25-07-2006, 04:49 PM   #6 (permalink)
tuxfan's Avatar
Where are you located thecyclone2k? I have never heard anyone recommending or using a HP DVD-Writer!! Does your dealer have max margin in HP products? But where are you located? It may be true if you are in a small town.
You can write single layer DVDs in Dual Layered writers. Thats not a problem for sure. I have a DL writer in my VAIO and it burns SL DVDs.
I have not yet bought DL DVD-R, but SL DVD-R of Moser Baer was somewhere around 22-25. That was some months ago.
Yes, if you are thinking long-term, go fo DL DVD R/W drivers.
tuxfan is offline
Old 25-07-2006, 05:32 PM   #7 (permalink)
Well, I am at Ranchi, Jharkhand which is a small town. The dealer said that in case of problems it might be easy to get replaced or repaired as they are the authorised people. They also said the gurantee works better with hp systems (I got assembled) but, they will get it done as they are the local dealers for hp disregard of my build.
My dad knows 'em so, I dunno if they are lying or saying truth?
So, are hp writers not that good??
BTW, have digit guys done any DVD-RW reviews lately??
Old 25-07-2006, 05:35 PM   #8 (permalink)
Google Bot
Pathik's Avatar
@cyclone i got a on site warranty of 1 year on my sony dru 820 a
Pathik is offline
Old 25-07-2006, 07:25 PM   #9 (permalink)
royal's Avatar
Smile Re: DVD-RW query
Well check out this month's CHIP
royal is offline
Old 26-07-2006, 06:55 AM   #10 (permalink)
Well, the reason those hardware guys gave was, if the rw got any problems it would be sent from here to Kolkata/ Mumbai and then some more places (I got sleepy by his lecture) so, it would take lot time.
My last CD-RW of LG got damaged due to internal reasons so, I want to confirm everything this time.
Thanks royal for your tip!
Old 26-07-2006, 02:40 PM   #11 (permalink)
tuxfan's Avatar
Frankly, I have never seen anyone recommending HP DVD writers so far. All are saying Sony and some say BenQ. But HP?? Not a single.
Why don't you inquire at some other dealers and see what they say about various brands?
tuxfan is offline
Old 26-07-2006, 05:32 PM   #12 (permalink)
hmmmmm.... well, I will ask other dealers then too.
And, what bout the speed? What is the best speed offered in terms of DVD-RWs??
Old 27-07-2006, 03:32 AM   #13 (permalink)
just to warn, thatIDE to usb convertor case is gonna shake all the gears inside, might loose the alignment
ashnik is offline
Old 27-07-2006, 03:47 AM   #14 (permalink)
rahul_becks23's Avatar
Lite-On SHW 1635S is a gr8 one....go 4 that.
rahul_becks23 is offline
Old 27-07-2006, 08:38 AM   #15 (permalink)
So, what's the current highest speed offered for DVD-RW?
and, is the x for DVDs, also equivalent for 150kbps?
Old 27-07-2006, 01:12 PM   #16 (permalink)
shashank4u's Avatar
out of :
1. shw 1635s,
2.shw 1693s,
3.shw160p6s,
4.shw165p6s
which is the latest model , as 1,2,3 are nearly the same
and 4. shw 165p6s have support for dvdRAM also.
which one u recommend guys :
thanx in advance.
shashank4u is offline
Old 27-07-2006, 02:44 PM   #17 (permalink)
Are you suggsting or hijacking my thread?
I had to google to figure what those things were?
Old 27-07-2006, 02:47 PM   #18 (permalink)
shashank4u's Avatar
these are the liteon dvd writers model no.s.
Old 27-07-2006, 04:59 PM   #19 (permalink)
Yp, I figured that by googling it.
So, is 16x is the best speed offered for DVD-RWs or something better can be found?
Old 27-07-2006, 08:02 PM   #20 (permalink)
Pharmaguru
kjuvale's Avatar
Hi, i want to buy liteon shm165p6s , can anyone give me approx price of it.
Its urggent as i am buying it tommorow.
My Photography gadgets :
Nikon D5100 with 18-55mm VR Lens, Nikkor AF-S 50mm 1.8g, Tamron VS 70-300 VC Di
Cullmann NANOMAX 220 Tripod. | Crumpler messenger boy stripes 4000 camera bag :grin:
kjuvale is offline
Old 27-07-2006, 08:15 PM   #21 (permalink)
ayush_chh's Avatar
i use HP 635i (Dual layered) it's fine.
for the price of blank media
DVD+R(single layered) costs around Rs.15-20 for avg. one
and >Rs. 20 for a good one
for DVD+R(Dual layered) in kolkata they say it will cost around 350 bugs ..
ayush_chh is offline
Old 28-07-2006, 03:53 PM   #22 (permalink)
I guess I can catch 350 bugs, every morning I will go to a park and catch some everyday! Just gimme a week! lol. BTW, any specific bug?? I am expert in catching Lady Birds, Grass Hoppers, Dragon Flies.... I guess I will hire Timon and Pumba!
Sorry for the joke! lol. I guess that's way too much for Dual layer, rather I will buy 2 single layers. But, how come PC magz offer that??
While, other qeuries are sorted out -
Is 16x is the best speed offered for DVD-RWs or something better can be found?
Old 29-07-2006, 11:15 AM   #23 (permalink)
i think thers 20X burners already out........check it out anyways.
Old 29-07-2006, 11:25 AM   #24 (permalink)
well finally guys i found a lite-on dealer at ctc. i visited atleast 20 shops for the lite-on drive. the shop guy didn't tell me the model no. well how lucky i was today. i found a 1635s on the display window and guess what? it was the last one he had! wo! now that was real cool and lucky!
i bought it for 2250. nevertheless i'm a happy man. the drive comes with a extra black bezel. didn't write any dvds but soon i will.
well thanks for all your replies guys. i really found them very helpful!
keep em comin!
neyo is offline
Old 29-07-2006, 12:06 PM   #25 (permalink)
ayush_chh's Avatar
nice one dude......
but thats wat the vendors say..
hav u ever tried the market?
Old 29-07-2006, 12:25 PM   #26 (permalink)
@neyo-
hey,cool man............that was some lucky shopping
Old 29-07-2006, 01:00 PM   #27 (permalink)
Originally Posted by ayush_chh
nice one dude......
They might be saying bucks not bugs! Maybe it was typo and you still haven't notices, no probs, it was just a PJ.
Thanks everyone for your tips!
