Old 22-07-2006, 07:33 PM   #1 (permalink)
Stalker's Avatar
Question What is DVD-Ram
hey, i just bought a lite-on DVD writer. using the nero info tool i found out that my drive does not support DVD-Ram & mount rainer(or something). What is this DVD-RAM & mount rainer?
| C2Q Q6600 G0 | Intel DG33FB | 4 GB Corsair 6400C5G DDR2-800Mhz | XFX 8800GTX | CM Extremepower 600W | 250GB Seagate HDD | Lite-ON 1635S DVD RW | Logitech MX-518 | Zalman RS6F | APC RS 800 |
Stalker is offline
Old 22-07-2006, 07:43 PM   #2 (permalink)
~It_is_Andrew~'s Avatar
Default Re: What is DVD-Ram
dont worry, DVD RAM is a yet another format of dvd media , mostly used in cams etc. Probably you will never need to use one in your pc.
Mount rainier is a special type of file system that supports packet writing. It is like UDF(universal Disk Format) which supports using RWs like floppy disk but mount raineir doesnt need any special software for that, its completely hardware dependent.
~It_is_Andrew~ is offline
Old 22-07-2006, 08:06 PM   #3 (permalink)
Stalker's Avatar
@~It is Andrew~
Thanks for replying & solving my doubts
Stalker is offline
