Re: HDD not working but how to confirm
I am also facing the same problem with my new seagate 200GB sata HDD.
Sometimes when i boot or i am already working on the pc...the hdd starts to make beep sounds with 1 sec interval and hhd light also blinks....kinda like when you insert a CD into a cdrom drive ...and it is detecting.
I have found that the HDD is ok. The problem is with the SATA cable itself.
Whenever this problem comes nothing works, and i need to disconnect the drive removing the cable from both the ends...then i replug it into another SATA port and voila it works.
But then again ...the problem repeats in a few days.
The permanent solution to all this is i guess to buy a shielded SATA cable, so that there is no data loss during transfer. Actualy after doing some research on the net i found that these SATA drives cannot recover after a data loss during transfer till you either restart pc or disconnect the cable....unlike the older PATA drives.
AMD Athlon64 2800+, MSI K8N Neo3(NForce4), 1GB Kingston DDR400, MSI Geforce 7600GT PCIe, Viewsonic VA702b 17" LCD, Creative SB Live! 5.1, Logitech Z-5300 5.1 THX Speakers, Seagate 200GB SATA HDD
