Re: INTEL 865GBF and GeFORCE 5500 Problem
try to download utilities like
nvhardpage
Rivatuner
powerstrip
u can mostly find them at guru3d.com. with them u can manually change ur agp settings i.e PCI mode, 1x, 2x, 4x or 8x.
using hardpage u can add a page(called AGP settings) in ur forceware driver control panel which will tweak ur AGP settings.
with Rivatuner or powerstrip u will find these options in the main control panel of the respective program.
i recommend rivatuner for this.
NOTE: AGP version 3.0 = AGP 8X
AGP version 2.0 = AGP 4X
865 does support AGP 8x.
| C2Q Q6600 G0 | Intel DG33FB | 4 GB Corsair 6400C5G DDR2-800Mhz | XFX 8800GTX | CM Extremepower 600W | 250GB Seagate HDD | Lite-ON 1635S DVD RW | Logitech MX-518 | Zalman RS6F | APC RS 800 |
