Old 19-07-2006, 09:58 PM   #1 (permalink)
Default how to cross crimp
I recently cross crimped a cable to connect two pc's. however it shows cable disconnected on both the computers . I have tried clamping it many times and also checked the order of the cables.
my cable is 33m in length is that the problem? what is the limit for the cable length?
izzikio_rage is offline
Old 20-07-2006, 07:49 AM   #2 (permalink)
In Pursuit of "Happyness"
kalpik's Avatar
Default Re: how to cross crimp
The cable is broken. Get it replaced.
kalpik is offline
Old 20-07-2006, 06:52 PM   #3 (permalink)
the cable works fine when i straight crimp it and join my pc to a switch. also th e guy who cross crimped it checked it with an ammeter and it worked fine. any other suggestion
