Old 19-07-2006, 12:09 AM   #1 (permalink)
Default 7600GS does not work on ASUS A8N-VM !!!!
On friday,14-7, I bought following config for a friend
AMD 3500+
ASUS A8N-VM mobo
512*Twinmos 400Mhz
Seagate 160GB
VIp 500W SMPS
and
BIG 7600GS 256 MB PCIe card
but the problem is that this card doesn't work on this mobo
When I install this card on mobo in PCIe slot and connect the monitor's data cable to it, I don't get the beep and display
but when i remove the card and use onboard vga all work well
I have tried the card on another A8N-VM too, but no success. PLZ help
If u guys think that i need a bios upgrade, then plz give me the exact linc to the file. I have never ever upgraded the BIOS of ne mobo. I had visited Asus site, but could not get the particular BIOS upgrade for A8N-VM. May be i was looking at right places. plz help.
BTW, can some one assure me that this 7600GS card will definitely run on MSi K8ngm2-L mobo w/o ne BIOS upgrade?
I need one more PC with same config 4 another friend.
ashnik is offline
Old 19-07-2006, 12:56 AM   #2 (permalink)
Default Re: 7600GS does not work on ASUS A8N-VM !!!!
download this file if u want to update the bios :
ftp://dlsvr03.asus.com/pub/ASUS/mb/s...8N-VM/0702.zip
Btw, do u have the latest nvidia drivers.. i think the latest being 90.xx..
rskbug is offline
Old 19-07-2006, 11:44 AM   #3 (permalink)
thx 4 quick reply buddy, i'll try that BIOS update. nvidia drivers is the later thing, let the sys boot atleast. this card is sh*tting me
ashnik is offline
Old 19-07-2006, 12:05 PM   #4 (permalink)
Ethan_Hunt's Avatar
Did you disable the onboard video?
This is necessary as your are shifting the cable of the montior to a stand alone card whereas the default of the motherboard is set to recognise the onboard video and hence won't boot up.Head out to the BIOS settings and disable the shared video memory first and then if there is a settings present to shift onboard to PCI-E enable it.This should do the trick.
V for Vendetta
Ethan_Hunt is offline
Old 19-07-2006, 03:58 PM   #5 (permalink)
Allwyn hit the spot. I think the problem is due to the onboard video. Disable it and the card should work just fine.
AMD 64 3500+ Venice
DFI Lan Party Ultra-D
XFX 7900GT 256 MB Card
icecoolz is offline
Old 19-07-2006, 05:26 PM   #6 (permalink)
hey ashnik BTW wat is cost of Asus A8N VM
who the hack is this??
mukul is offline
Old 19-07-2006, 07:59 PM   #7 (permalink)
@allwyn
well i have tried every possible setting at the northbridge in BIOS. Actually there is no way that we can completely disable the onboard VGA. there are only 2 options,
1)IGP->PCIe->PCI
2)PCI->PCIe->IGP
Not only this, I also tried to make the onboard buffer zero MB, but still the sys refused to boot.
@MUKUL
the 3500+ and A8N-VM combo fetched me 10.5K
I'll post the BIOS upgrade report soon.
BTW, which mobo will run this card out of box. As i Have said I need to build another sys.
ashnik is offline
Old 20-07-2006, 07:29 AM   #8 (permalink)
thanks for the price
this can be run at A8N E ...5500 bucks
better ,stable ...and prtty featured Mobo....its better choice 4 u as u have a graphic card ....while A8N VM is for ones lukin for integrated solution...
mukul is offline
Old 20-07-2006, 02:24 PM   #9 (permalink)
don't expect to game with 512mb ram.
akshayt is offline
