| Forum |
#1 (permalink) |
I know this type of question has been posted many times, but still I am confused and need your help urgently. i need to upgrade my computer which is 3 years old, quickly. i don't know much about hardware and i need the following parts and came up with these possibilities:- please help. Motherboard - Intel D101GGC CPU - Intel Pentium D 2.66 GHz 805 or Intel Pentium4 3.0 GHz HT 630 Cabinet - Antec Black SOHO Tower case TX1050B (my brother's heart is set on it.) DVD Writer - BENQ DVD DD DW1650 Graphics Card- XFX GeForce 7600GT 256MB PCI-Express DDR3 please help me decide and tell me what to change. also could anyone tell me where to find them in Kolkata. thanks in advance. |
#2 (permalink) |
Most of the hardware u'll get it from Eastern logica in Ganesh ave, and for antec cabinets u'll get at Alfatech at kamalaya centre, Lenin sarani.
Why don't u go for AMD soln? Also u need minmum 512MB ram.U should also think of buying new sata hdd. |
#3 (permalink) |
Intel Pentium D 2.66 GHz 805 is not so good compaired to latest AMDs. U shd go for somewhat higher Pentium D processor.
If u want to stick with Pentium D, wait for a few weeks bcoz Intel will slash the prices of all of its processors. Otherwise go for AMD AM2 or Intel Conroe; but for Conroe, u'll have to wait a while....
Intel Core 2 Duo E6300, Intel DG965RY, MSI 8600GT OC, WD 250GB SATA-II Harddisk, Transcend 1GB 667 Mhz DDR2 RAM, Samsung Samtron 55V, Sennheiser HD485 cans, Zebronics LAVA Cabinet, Zebronics 400W PSU |
#4 (permalink) | |
2>ok......if u can then AMD X2....or PD 805 os ok....for a mid range desktop. 3>Cool...... 4>Cool..... 5>Double cool cool
Sam |
#5 (permalink) |
You are buying a gaming comp, right?
All the components are incorrect except maybe the graphic card, you will need to change everything. Amd 64 3500 Venice : 5700 or amd 64 3000 Venice : 4500 Venice is a highly overclockable chipset and these cpus even at stock will beat both those cpus in gaming. Asus A8N E : 5500 or so 2 X 1GB DDR 400 Transcend ( UCCC chips, if not available then Hynix D43 chips) DVD RW Sony, Benq should be ok but I advise Sony, bad expereince with Benq CD RW, a part of it is very sticky and can damage the cd. A local cabinet PERIOD, your budget is very low so you can't get anything more than something which costs about 1500 tops. PSU, atleast a Cooler master 430 for 2700 if you plan to oc a lot and all, then get something more power ful like Cooler mater igreen 500 or igreen 600 your graphic card is ok, but seriously do consider Radeon X1800GTO as well. try to extend your budget to accomodate a 7900GT, 17k + HDD 250 sata II NCQ SEAGATE : 4200 300 : 4800 |
#6 (permalink) | |
Does the new AMD CPUs based on the AMD AM2 CPUs have Venice Cores too? What abt AMD X2 Cores?
#7 (permalink) | |||||
thanks to all of you guys for your very prompt help.
thanks for suggesting AMD i've some reasons for sticking to Intel. if i could. i'd wait for Conroe, but i'm in a hurry. Quote:
my budget is kind of flexible, but i'd rather not spend too much now. do u guys think my configuration could last another year, may two? i could upgrade then. from what i can see, something new is always coming along. i heard that intel is already working on four core processor. so... Quote:
| Bookmarks |
| Thread Tools | |
| Display Modes | |
