Old 17-07-2006, 01:48 PM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
I am Optimus Prime
navjotjsingh's Avatar
Default PC does not starts....beeps+blinks
For past 2-3 days when I press the power for my PC...it does not start...monitor remains on yellow indicator and red indicator on CPU blinks alternatively and a very low beep sounds alternately...I have to switch it off and on atleast 10 times to see monitor showing some activity and then Windows XP loading screen....Any Idea what's the problem...seems a hardware problem to me...but can't figure out what's the actual problem?
navjotjsingh is offline
Old 17-07-2006, 01:59 PM   #2 (permalink)
DeSmOnD dAvId's Avatar
Default Re: PC does not starts....beeps+blinks
Can you tell how exactly does your CPU beep?
For ex: beep beep beep (or) beeeep beep beep.
"If God had wanted you to live he would not have created ME!"
Steam : Rrtry™ DeathMetal
My Blog : The Pandemonium (Latest Post : Where does music come from?)
Need new Electric guitar...help needed!!!
DeSmOnD dAvId is offline
Old 17-07-2006, 02:01 PM   #3 (permalink)
I am Optimus Prime
It beeps like
beep beep beep and red light blinks with each beep. Monitor is on yellow light...switched off condition.
Old 17-07-2006, 02:10 PM   #4 (permalink)
If you are using Award BIOS, that means that your RAM is faulty. Try fitting the RAM tightly in their slot and try again. If the prob still exists, get it checked from your nearest Computerwala.
LinkBack to this Thread: http://www.thinkdigit.com/forum/hardware-q/32133-pc-does-not-starts-beeps-blinks.html
Thread 1 beep + 5 fast blinks, 3 beeps + 4 blinks, 1 beep + 2 blinks | Apple - Support - Discussions | BoardReader This thread Refback 22-06-2010 11:38 PM
