Old 16-07-2006, 05:55 PM   #1 (permalink)
a_g = JPKN
s18000rpm's Avatar
Default Driver for DVD Burner
i have this "NEC DVD+RW ND-2100AD" DVD Burner.
the problem is that this drive shows a lot of "CRC errors " when i put a DVD (files burned on it from another PC"). sometimes it doenst play Movie DVD.
I dont have the Drivers CD with me, & i searched (googled) a lot with no results.
Can someone give me a link to this model's Driver , or a Firmware would also help.
My PC Config. HP Pavilion, XP SP2,
P.S. I tried updating the drivers using Device Mangr. but of no use.
& i upgraded to a DVD Burner when buying the PC, So HP cannot help me.
s18000rpm is offline
Old 16-07-2006, 07:09 PM   #2 (permalink)
In Pursuit of "Happyness"
kalpik's Avatar
Default Re: Driver for DVD Burner
There are no special dirvers required for any DVD Writer! Windows will automatically detect it..
kalpik is offline
Old 16-07-2006, 07:14 PM   #3 (permalink)
Google Bot
Pathik's Avatar
yup and if the drivers r there they ll only be for advanced functions
not for normal functions....
Pathik is offline
Old 16-07-2006, 10:58 PM   #4 (permalink)
deathvirus_me's Avatar
No drivers necessary .. but u can check for updated firmwares ...
deathvirus_me is offline
- by soumya
- by tv6952
