Old 15-07-2006, 01:15 PM   #1 (permalink)
Cool External HDD
hi
I need an external HDD for my laptop.
can I get THOSHIBA here?
I am at kerala.
gimme the brands, price and specifications,
If possible do gimme links
Its urgent,
thanx,
krive.
whizkrive is offline
Old 15-07-2006, 01:38 PM   #2 (permalink)
samrulez's Avatar
Default Re: External HDD
Dude don't go for toshiba external hdd.......just get a normal IDE hdd and get a casing...which will convert the IDE to USB interface.......
the casing should cost u between 0.5k to 1.5k.........
and the a 80 gig hdd should be around 2k........so u get an external hdd for 2.5k.....
Sam Rulez
samrulez is offline
Old 16-07-2006, 09:02 AM   #3 (permalink)
You can follow the advice given by Samrulez but try to get a branded casing if possible. Branded external HDDs are available but I doubt you will easily find it in Kerala. You may try at Ernakulam. Or else, try online shops like deltapage.com, itdepot.com, computerwarehouse.com but their prices will be on the higher side.
BTW, where in Kerala are you? I am at Kollam.
V.Prem Kumar
janitha is offline
Old 16-07-2006, 08:57 PM   #4 (permalink)
hi
thanx 4 ur reply,
I am at Trichur.
pls gimme some links for branded ext. hdd's
krive.
Old 16-07-2006, 10:48 PM   #5 (permalink)
Originally Posted by whizkrive
hi
thanx 4 ur reply,
I am at Trichur.
krive.
I have already given the links.
And until recently I was working at Trichur.
V.Prem Kumar
janitha is offline
