Old 15-07-2006, 11:15 AM   #1 (permalink)
dissel's Avatar
Default Can't Boot from (Sony DRU - 810 A)
hi,
I have strange problem with my dvd-writer (Sony DRU-810 A).It can't boot the OS.....(let me clear)...
when i try to format my machine...and assign this optical drive(DVD-Drive) as fast boot device in the bios it can't boot from the XP cd....the cd is absoloutly perfect and i format from that cd couple of times....even i try the diffrent XP cds and other several OS like PC BSD,Fedora Core,Mandriva,Ubuntu (Original) all are bootable disc....and the condition is fine.
again when i am trying with a diffrent optical drive in my machine.....everthing is fine.It proves that there is nothing wrong in my whole system(i,e Bios/HDD).
Now my question is the Sony DRU-810 A not capable to booting OS ?
or my drive is deffective?
How i can solve this problem ? is there a firmware update needed ?
I don't know anything about firmware update....
If there is any weblink plz.....mention.....
Besides this till now there is no problem with my DVD-Writer.....
My machine Conf:-
Intel Pentium 4 3.0 Ghz
Intel 945 GTP
1GB DDR2 566 MHz
160GB SATA 7200 RPM Seagate
1.44 Sony FDD
Sony DRU-810A (Burning Software Nero 7)
N.B:-i bought the dvd-writer in october 2005....but it is the first time now when i need to use this drive to format my machine.
dissel is offline
Old 15-07-2006, 02:14 PM   #2 (permalink)
samrulez's Avatar
Default Re: Can't Boot from (Sony DRU - 810 A)
Well.....for boothing the optic drive should the master...and not slave...so check that.......
Sam Rulez
samrulez is offline
Old 17-07-2006, 10:36 PM   #3 (permalink)
dissel's Avatar
There was only one IDE device in my sysytem and it set as a primary master....coz the 945 mobo have only 1 IDE channel.
HDD is the sata....
dissel is offline
Old 17-07-2006, 11:25 PM   #4 (permalink)
-The BlacKCoaT Operative-
Rollercoaster's Avatar
may be the lens/cd is dirty
Rollercoaster is offline
