Old 14-07-2006, 07:34 PM   #1 (permalink)
Default Display Problem
I PC has a strange problem. There is no dispaly and a continous beep sound emanating. But as I remove the monitor cable form cpu it shows check the cable. I know monitor is perfect.
salztech is offline
Old 14-07-2006, 10:11 PM   #2 (permalink)
Wise Old Crow
blueshift's Avatar
Default Re: Display Problem
#from where?
#where does it show?
#How do you know?
Which monitor do u use? How old is tht? were there any such problems in the past or this is the first time?
blueshift is offline
Old 14-07-2006, 10:44 PM   #3 (permalink)
deathvirus_me's Avatar
Ram ??
deathvirus_me is offline
Old 14-07-2006, 11:11 PM   #4 (permalink)
Wandering in the zone ...
manas's Avatar
Check if your RAM modules are in place.That may be the problem.
Not all those who wander are lost.
http://www.manast.com ---- ManasT
manas is offline
Old 14-07-2006, 11:44 PM   #5 (permalink)
1337 |)00|) \m/
kaustav_geek's Avatar
Yup,
Continous beeps indicate RAM prob.
If (system worked before==1)
Check your RAM modules. Try removing them. Clean the edges(contacts) with an eraser. Then put them back in and boot. If the problem persists, try testing the RAM on another machine(if possible, ask your vendor to check them in front of you).
else
Change the RAm;
My Blog : www.vatsuak.blogspot.com
My DA page : www.burningsilver.deviantart.com
OK..ok..... Ads are bad..
kaustav_geek is offline
