Old 14-07-2006, 01:56 PM   #1 (permalink)
Default Asus A8N-VM CSM Motherboard
me just upgrading my pc from intel 2.8 to AMD 3500+....
and ram--->2GB
in this i would like a descent mobo....how is this one...
will i be able to play games on it....
plz suggest others too.....
i would like to play games on it at medium or low resolution or so... so suggest accordingly.....
may be later i hook up to graphic card....
plz reply soon...
who the hack is this??
mukul is offline
Old 14-07-2006, 02:13 PM   #2 (permalink)
samrulez's Avatar
Default Re: Asus A8N-VM CSM Motherboard
and ram--->2GB
plz reply soon...
Well.....u can play games on the A8N VM CSM......but don't expect too much from it.....maybe at low-mid settings with 25-35 fps....around..
Its a good option to get the A8N CSM...and then add a graphics card later........Maybe after a few months a 7600GT to 7900GT some card........only if u will be going for a graphics card later buy a good SMPS......ocz they require lotta power....
Sam Rulez
samrulez is offline
Old 14-07-2006, 03:17 PM   #3 (permalink)
Get one thing right, to play todays games(the latest ones) even at 10X7 low to med or med to high for some others you will need atleast :
1GB ram
Geforce 6600GT
no onboard video can do that
You won't be able to play games as well as you think you will.
Get Asus A8N E instead of that mobo, it costs maybe around 5500 and will probably be a much better mobo, oc, stable and all.
Right now you are getting:
Amd 64 3500 + your mobo = 9500
GET THIS instead and it will win over its performance:
Amd 64 3000 + Asus A8N E = 10k
+ sub 5k graphic card and this system will kill that system
keep in mind that all these systems are crap at gaming.
akshayt is offline
Old 14-07-2006, 03:47 PM   #4 (permalink)
but as i said i would like to invest ... in graphic card later ... i would bye a nice one later....till then i be needin onboard graphics ...
or if still go about with AMD 64 bit 3500+ with asus A8N E+ with a descent card .... how much would it cost me....also tell ab2 the card ,,,
mukul is offline
Old 14-07-2006, 03:58 PM   #5 (permalink)
I am not suggesting you a decent card in this budget unless you want to know.
Anyway a cheap way.
Amd 64 3000/3500 : 4500/5700
Asus A8N E : around 5500 maybe a tad more
Geforce 7300GT preferably GDDR3 , better still 7600GS, this one is the closest ot decent I have told you yet, 4.4k, 5kish and around 7k for 7600GS
Cheaper way
get Foxcon mobo without onboard video for around 2k
akshayt is offline
Old 14-07-2006, 04:04 PM   #6 (permalink)
Cheapest .. get a foxconn motherboard without any onboard graphic solution for 3k and go for a 6600 for 5k or 7300Gt
cyrux is offline
Old 14-07-2006, 04:06 PM   #7 (permalink)
foxconn mobo should be around 2k i think, read at TE forum
akshayt is offline
Old 14-07-2006, 04:42 PM   #8 (permalink)
1337 |)00|) \m/
kaustav_geek's Avatar
Man, do you seriously think that a 3000+ will kill a 3500+????
Well, I suggest that mukul goes for a 3500+ & Asus A8N-VM CSM combo. IF you go for a gfx card now, then go for the Asus A8N E.
If you are tight on budget, then replace the 3500+ with a 3200+ or atlast a 3000+.
My Blog : www.vatsuak.blogspot.com
My DA page : www.burningsilver.deviantart.com
OK..ok..... Ads are bad..
Last edited by kaustav_geek; 14-07-2006 at 04:48 PM. Reason: Automerged Doublepost
kaustav_geek is offline
Old 14-07-2006, 05:01 PM   #9 (permalink)
Anyway a cheap way.
Cheaper way
ok suggest a decent graphic card also... <10k
and gimme link for foxconn mobo too
what ab2 this mobo..... foxconn NF4UK8AA-8EKRS
http://www.foxconnchannel.com/EN-US/...D=en-gb0000140
mukul is offline
Old 14-07-2006, 05:54 PM   #10 (permalink)
Amd 64 3000 + 7900GT > Amd X2 4200 + 7600GT in almost all games.
Amd 3000 + good mobo + much better graphic card will easily kill a 3500. PERIOD
To top it, Asus A8N E will let you overclock your Amd 64 3000, then it might even comare to Amd 4000+
akshayt is offline
Old 14-07-2006, 07:32 PM   #11 (permalink)
1337 |)00|) \m/
Can you tell me why is it so?
Old 14-07-2006, 08:20 PM   #12 (permalink)
why what is so?
akshayt is offline
Old 14-07-2006, 11:29 PM   #13 (permalink)
1337 |)00|) \m/
Mention the sources which tell :
Well you might say 7900gt beats 7600gt coz its faster not because 3000+ beats 3500+.
Old 15-07-2006, 09:52 AM   #14 (permalink)
Amd 64 3000 + 7900GT > 7600GT + X2 4200 for most games
An overclocked Amd 64 3000(at 2.8) will surely beat or equal a Amd 4000, this is mostly maths.
For deriving the first you need to do some logic and maths :
GPU benchies
http://xbitlabs.com/articles/video/d...-x1800gto.html
Now you have an idea how a graphic card performs with a good CPU.
http://www.tomshardware.com/2006/05/...de_2006_part3/
Now you have an idea how a GPU performs with a mainstream CPU.
But still we need to know whether a better CPU helps or not, right, read on.
CPU benchies
http://www23.tomshardware.com/cpu.html
Please select gaming bechies preferably at high res and all.
http://xbitlabs.com/articles/cpu/dis...pu-games2.html
Do keep in mind that what I say is only true if you play at high settings, maybe 12X10 MAX or 10X7 MAX not if you are going to be doing 800*600 MED or something.
http://enthusiast.hardocp.com/articl...hlbnRodXNpYXN0
This is is a really important one for you.
The only downside is that they haven't all shown the min fps.
akshayt is offline
