| Forum |
#1 (permalink) |
what all hardware do i need ? what is the cheapest solution to this ? i want a solution so that i don't have to keep both the pcs on for accessing net. INFO: os:winxp processor: p4 ram:256 in one and 512 in other |
#2 (permalink) |
u will have to have
1) 2 lancards in Host PC (where u will have Broadband Installed) and 2) 1 lancard in second pc 3) Now lets take 2 lancards on Host PC a) Broadband b) Local LAN 4) now setup a network on both the machines but use only b) lancard 5) on Host b) lancard give ip : 192.168.0.1 and subnet as 255.255.255.0 6) on second PC lancard give ip : 192.168.0.10 and subnet as 255.255.255.0 7) Use same workgroup 8.) Enable filesharing 9) Turnoff Firewall at Local Lan connection 10) Configure Lancard a) for Broadband Connection 11) rightclick on ur Broadband Connection and Use Internet connection sharing and select Local Lan from the List 12) now u will b able to share Internet connection... or use any proxy server for sharing install it on Host PC and clofigure the second pc as suggested in its help..... thanx
Sharing Knowledge Expands Horizon... And Problems r solved |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
