Old 13-07-2006, 06:54 PM   #1 (permalink)
arcticflare's Avatar
Default ipod shuffle prob
whenevr i connect my ipod shuffle to the usb port it simply blinks and neither the itunes nor the system are recognizing it. Even the ipod icon doesn't appear in the devices with removable media. This happened recently and befor that my system had no prob detectin the ipod. But the funny thing is that the pc still detects a usb mass storage device present and the 'safely remove hardware' icon appears. Plz can anyone help me out. I can't get my songs into the shuffle now.
arcticflare is offline
Old 14-07-2006, 05:46 PM   #2 (permalink)
 Macboy
goobimama's Avatar
Default Re: ipod shuffle prob
Do you by any chance have the "yahoo widgets engine" running in the background? cause I had the exact same problem.
I'm like a bird... :)
goobimama is offline
Old 14-07-2006, 05:55 PM   #3 (permalink)
wats yahoo widgets engine. It worked fine before and now without any new prog installed it's gone bonkers.
Old 15-07-2006, 02:18 PM   #4 (permalink)
 Macboy
goobimama's Avatar
If it does not work on any other computer, then give it back for a replacement. Otherwise, just do a quick reinstall of windows....
Old 15-07-2006, 05:23 PM   #5 (permalink)
reinstall windows!! replacement is out of the question coz i had it frm US. Does this happen only with shuffles or even with nanos
Old 15-07-2006, 07:05 PM   #6 (permalink)
trigger_happy's Avatar
Lightbulb Re: ipod shuffle prob
Dude just open ur ipod as a mass storage device. There will be a hidden folder <sorry i 4get its name>, anyway open the hidden folder, open the music folder and copy paste ur songs into the folder called F00 or F001<any folder>. Enjoy!
trigger_happy is offline
Old 15-07-2006, 08:31 PM   #7 (permalink)
champ_rock
champ_rock's Avatar
try to format ur ipod...
go to the ipod software and restore it to original state...
and by the wya if u r using itunes to manage ur songs, i recommend u to http://shuffle-db.sourceforge.net/
Registered Linux user number 400618
champ_rock is offline
Old 16-07-2006, 02:12 PM   #8 (permalink)
the prob is my pc wont sdisplay the externa drive icon when ipod is inserted. And i think it's my ipod's faulty coz my bro's ipod shuffle is gettin detected properly
Old 16-07-2006, 03:17 PM   #9 (permalink)
Tux Fan
shaunak's Avatar
try connecting your brothers ipod with your pc using your cable so as to check if your cable is at fault or your i pod.
Cheers
Shaunak
Feel free to PM/email me.
shaunak is offline
Old 16-07-2006, 09:13 PM   #10 (permalink)
shuffles don't have cables, they are inserted directly as thumb drives
Old 17-07-2006, 08:00 PM   #11 (permalink)
champ_rock
champ_rock's Avatar
have u tried formattiing the ipod just as i suggested earlier
Old 18-07-2006, 12:57 PM   #12 (permalink)
you can upgrade the firmware and that would solve the problem
but remember that it is not easy to do that
firmware upgrade if proper can solve your problem or even worse
not my responsibility man
do it at your own risk
maheshmax is offline
Old 18-07-2006, 05:58 PM   #13 (permalink)
thnx for ur help dudes but i think the ipod has died down. The pc won't even show that ipod is connectd but only displays a safely remove hardware option whenever the ipod is inserted. so the question of formattin or firmwre upgrade doesn't arise. Thnx for ur help tho.
