Old 13-07-2006, 06:25 PM   #1 (permalink)
pop143's Avatar
Smile Wot 2 do with PII.?
hi friends..
my friend has an old pII 266mhz computer. his motherboard has some power component problem and the hardware technicians told them , tough 2 fix motherboard..so change it. and its also tough to get a motherboard for a p2 in these days.
his processor , hdd, fdd, cd drive ram are all working in good condition..
wot 2 do with this cpu now??? it wont go for a decent resale price also.
can anybody give a hint...for its max good usage..??
pop143 is offline
Old 13-07-2006, 07:06 PM   #2 (permalink)
dIgItaL_BrAt's Avatar
Default Re: Wot 2 do with PII.?
u could install Linux on it.
dIgItaL_BrAt is offline
Old 13-07-2006, 07:17 PM   #3 (permalink)
18 Till I Die............
But without a mobo how will it run?
http://www.bash.org/?258908
mehulved is offline
Old 13-07-2006, 07:18 PM   #4 (permalink)
oops,my bad.
Old 13-07-2006, 07:28 PM   #5 (permalink)
there are only two options as far as i can see... One, sell the processor, but you wont get a good price for it. Two, try to get a second hand mobo for the proccy and get a backup computer.. But it will be hard to get the second hand mobo afaik...
Arun
sakumar79 is offline
Old 13-07-2006, 07:31 PM   #6 (permalink)
Maybe you can try someone you know and has an old computer still lying around. Not to mention too are too low for that.
mehulved is offline
Old 13-07-2006, 07:43 PM   #7 (permalink)
pop143's Avatar
Smile Re: Wot 2 do with PII.?
hmm....thans for ure suggestions guys...
all the prob id the motherboard for the p2 .
more over it has 16mb ram and 2gb hdd. by the way is there any mobo like built in processor?? i heard something like that..!!! wud that be a cheap alternative to replace to p3 celeron instead..??
pop143 is offline
Old 13-07-2006, 08:49 PM   #8 (permalink)
Look for VIA C3 kits. They come in a cpu+mobo combo. However ur current ram may not run in that. Infact nothing sells right now that uses SDRAM.
C2D E8400@3.8, P5N32-E SLI, 2GB Cellshock DDR2 1000(4-4-4), 8800 Ultra SLI, 2.7TB storage, CM Stacker 830, TT 1200W, Dell 2005FPW, Lots of Audio HW.
Ch@0s is offline
Old 13-07-2006, 08:53 PM   #9 (permalink)
pop143's Avatar
VIA c3--cud u give some extra details...??? how much wud it be?? wot type processor pentium or celeron??? will it support ddr ram..????
thanks
pop143 is offline
Old 13-07-2006, 08:57 PM   #10 (permalink)
Via C3 is the name of the CPU duh.. . Its the cheapest thing you can get. AFAIK, the mobo+CPU will cost around 3K. You need to get DDR memory for it cos it doesn't accept SDRAM.
Ch@0s is offline
Old 13-07-2006, 09:01 PM   #11 (permalink)
pop143's Avatar
if possible..cud u give a link to the thing..u r specifying...?
cud u give the approx price for this..??
pop143 is offline
Old 13-07-2006, 09:06 PM   #12 (permalink)
Here you go
http://www.via.com.tw/en/products/processors/c3/
Don't expect to play games on it but it'll definitely be faster than that P2 233.
Ch@0s is offline
Old 13-07-2006, 09:16 PM   #13 (permalink)
gooby pls
Third Eye's Avatar
donate it.
Third Eye is online now
Old 13-07-2006, 09:21 PM   #14 (permalink)
pop143's Avatar
Originally Posted by tech_mastermind
donate it.
that also..we tried..nobody ready 2 accept it...bcoz they wanted 2 play good games..!!
pop143 is offline
Old 15-07-2006, 01:37 AM   #15 (permalink)
dattebayo
anispace's Avatar
I also have my P2 333MHz comp. works perfectly.... but no use for it. So i hav just packed and stored it.
Yoda: No. Try not. Do... or do not. There is no try.
anispace is offline
Old 15-07-2006, 01:47 AM   #16 (permalink)
pop143's Avatar
if anybody can send me a p2 motherboard, there r two of my brothers in relation , eager to have a computer at home. it wud be really helpful for those kids to use and learn computers at this age. so only am thinking 2 do some help.please anybody can do help , assist me;
pop143 is offline
Old 15-07-2006, 12:37 PM   #17 (permalink)
-The BlacKCoaT Operative-
Rollercoaster's Avatar
DO A MOD.
built some kind if information station of it. place the CRT(or small 8"x6" LCD it u can afford it) somewere like roof corner/wall mount.. reporting weather n tv schedule n rss news.. add IR reciever and a remote(it is cheap) to do some remote controlling.
actally that is what i am planning to do with my old pIII 1GHZ comp. so OOPS the idea is out.
chk this
http://www.avsforum.com/avs-vb/archi.../t-636947.html
http://www.silentpcreview.com/forums...&highlight=pii
^>>>http://sparkytfl.no-ip.org/Server.html
one guy somewere says
"Assume for the sake of argument that the computer in question has something between a 266MHz PII and a 1GHz PIII, and 128k or less of RAM. thats not a computer, thats a caculator "
LOL
Rollercoaster is offline
Old 15-07-2006, 01:21 PM   #18 (permalink)
pop143's Avatar
k,...for that my motherboard is repair.......wot 2 do..?? everything is k..if i can get a new motherboard..!!
pop143 is offline
