Old 13-07-2006, 03:50 PM   #1 (permalink)
Question gud TFT needed!!!
i wanna buy a very good tft 17or19"
with DVI IN
tell me if there is any gud 17" wide screen tft
INTEL IS INSIDE BUT AMD IS EVERYWHERE..
thinktwice is offline
Old 13-07-2006, 05:11 PM   #2 (permalink)
Default Re: gud TFT needed!!!
What is your requirement, if it is gaming then you will need to think again, not all TFTs are good for gaming and your budget will become a major factor.
If you want to buy starting level TFTs then you will get 17" sub 20k, to be more precise close to 12k(not sure), or maybe 13-14k to 17-18k
akshayt is offline
Old 13-07-2006, 08:59 PM   #3 (permalink)
Samsung 940BW 19" Widescreen 4ms display. Costs round 17K.
C2D E8400@3.8, P5N32-E SLI, 2GB Cellshock DDR2 1000(4-4-4), 8800 Ultra SLI, 2.7TB storage, CM Stacker 830, TT 1200W, Dell 2005FPW, Lots of Audio HW.
Ch@0s is offline
Old 14-07-2006, 09:08 AM   #4 (permalink)
Keep in mind that to stick to the native res of even a 17" monitor, I think you will need to upgrade to a high end card atleast once a yr.
Hi end: 25-30k or more.
akshayt is offline
Old 14-07-2006, 01:22 PM   #5 (permalink)
mayanksharma's Avatar
Look out for the Viewsonic TFT widescreen and 19" models.
They have good response times varying from 2 to 4ms!
mayanksharma is offline
Old 14-07-2006, 01:29 PM   #6 (permalink)
The Hardware Labs
mohit's Avatar
get this ...n try bargaining ..its a good one and the price is damn sexy.
mohit is offline
Old 18-07-2006, 02:06 PM   #7 (permalink)
thanks chaos!!!!
but it's so cheap ....r u sure the quality is good????
i didnt find any 940BW there!!!!
r u sure it has DVI IN....
Old 18-07-2006, 02:26 PM   #8 (permalink)
bad quality monitor with low ms may cause trails.
akshayt is offline
Old 18-07-2006, 09:27 PM   #9 (permalink)
But I think the more ms (response time), the more ghosting. ie., the lower response time (in ms) the better.
V.Prem Kumar
janitha is offline
Old 19-07-2006, 09:47 AM   #10 (permalink)
u didnt replied ....it has DVI IN or not??
Old 19-07-2006, 07:45 PM   #11 (permalink)
TeChRocK's Avatar
for Samsung 940BW no DVI IN only D-sub. try benq products has both DVI and D-sub http://www.benq.co.in/products/LCD/?...specifications
TeChRocK is offline
