Old 13-07-2006, 03:31 PM   #1 (permalink)
Question suggest me the best dual layer dvd writer
suggest me the best dual layer dvd writer plz
INTEL IS INSIDE BUT AMD IS EVERYWHERE..
thinktwice is offline
Old 13-07-2006, 04:06 PM   #2 (permalink)
Default Re: suggest me the best dual layer dvd writer
check out this link
dvd writer needed urrrrrrrgent....
Suggest me a DVD Burner
Ppl plz b4 posting a thread make use of the
SEARCH BUTTON...............
rskbug is offline
Old 13-07-2006, 05:11 PM   #3 (permalink)
HELP AND SUPPORT
rakeshishere's Avatar
LG DVD WRITER is the best..I am using it since 3yrs and has no problems
rakeshishere is offline
Old 13-07-2006, 09:51 PM   #4 (permalink)
In Pursuit of "Happyness"
kalpik's Avatar
@thinktwice: why dont you just "watch" once before posting?
kalpik is offline
Old 13-07-2006, 11:28 PM   #5 (permalink)
Manchester United
abhijit_reddevil's Avatar
I have sony DRU820A and I think it is one of the best dual layer DVD-writers around. It is basically Benq DW 1650 rebadged...
PS3-Ipod Touch 4G-Samsung Galaxy Ace-Sapphire HD 6870 Twin Frozer-Creative Zen:cloud9:
abhijit_reddevil is offline
Old 14-07-2006, 12:16 AM   #6 (permalink)
DRU820A is Benq 1670 rebadged not 1650. It is *NOT* a very good drive.
C2D E8400@3.8, P5N32-E SLI, 2GB Cellshock DDR2 1000(4-4-4), 8800 Ultra SLI, 2.7TB storage, CM Stacker 830, TT 1200W, Dell 2005FPW, Lots of Audio HW.
Ch@0s is offline
Old 14-07-2006, 12:54 AM   #7 (permalink)
18 Till I Die............
OK check out the other threads. Closing this one.If you have any problems ask there.
http://www.bash.org/?258908
mehulved is offline
