Old 12-07-2006, 09:27 PM   #1 (permalink)
Smile Please help me to build my new pc
Hello Guys,
I would like to build my new pc. My budget is around 35,000. I have already got 17" monitor. My main use will be doing office work, playing games & other normal multitask work. I am thinking of following configuration. kindly suggest me if you have better idea.
1) Intel P4 3GHZ D-930 Dual Core CPU
2) Intel 845 Mother board (Suggest me any good mobo)
3) 1 GB DDR2 Ram
4) 256 MB PCI Express card (Plz suggest me good card under Rs 5000)
5) ATX Cabinet with 400 Watts Power Supply
6) 250 GB Seagate SATA Hard Disk
7) Normal Samsung Kb/ Mouse
Thanks in adavnce for your replies.
http://www.hostfornet.com
birbal is offline
Old 12-07-2006, 09:49 PM   #2 (permalink)
samrulez's Avatar
Default Re: Please help me to build my new pc
Originally Posted by birbal
Hello Guys,
3) 1 GB DDR2 Ram
1)930 is okay.............................................. ................6000-7000
2)845??? I think u mean 945.......Try and go for ASUS.........4000-6000
3)go for 512X2 ram sticks............................................ ...5000
4)nVidia 7300GT/7300GS............................................ .....5-6k(not sure)
5)Zebronics....400 watt SMPS and Cabinet.........................1500-2000
6)Seagate 200 GB SATA(II).......................................... ....4000
7)Microsoft/Logitec combo............................................. ..800
Sam :D Rulez :lol:
samrulez is offline
Old 12-07-2006, 10:01 PM   #3 (permalink)
deathvirus_me's Avatar
Hmm ... the prices looks ok .. but ru sure the 300 GB is for 4k's ??? I think its more like 5k's ...
deathvirus_me is offline
Old 12-07-2006, 10:13 PM   #4 (permalink)
samrulez,
Thanks for your reply.
Yes I mean 945 series mother board.
Does Asus mother board really impact the performance ?
SATA (II) HD easiliy available in market ?
Do you know any place in Mumbai where I can get best deal for above hardwares ?
Thanks once again for your suggetions
birbal is offline
Old 12-07-2006, 10:26 PM   #5 (permalink)
samrulez's Avatar
Ooppss....that was a 200gig...sorry....
And ASUS rocks......There are minute problems with intel originals.....stay away....
Yes SATA (II) hard disks are very easily available..in the market...
The best place would be at lamington.....don't go to small..dumb shops...go to Prime ABGB or some similar shop......
Sam :D Rulez :lol:
samrulez is offline
Old 12-07-2006, 10:33 PM   #6 (permalink)
Intel originals DON"T LET U OC ... so they SUCK bigtime ... Asus , MSI .. anything but Intel originals ...
Old 12-07-2006, 10:35 PM   #7 (permalink)
samrulez's Avatar
What I meant was Intel mobos......not chipsets...
Chipsets are ok...but not as good as nVidia.....
Sam :D Rulez :lol:
samrulez is offline
Old 12-07-2006, 10:43 PM   #8 (permalink)
Thumbs up Re: Please help me to build my new pc
I know Prime Computers but what is ABGB ?
Also why do you recommend 512 MB 2 stick instead of single 1 GB stick ? any particuler reason behind it ?
Also if you know Asus 945 model mobo number then plz let me know.
Thanks once again for your quick reply....u rock
birbal is offline
Old 13-07-2006, 02:17 PM   #9 (permalink)
samrulez's Avatar
The shop is named Prime ABGB.....
PRIME ABGB PVT. LTD
Shop no.16, Laxmi Building Compound,
Lamington Road, Mumbai 4
Phone nos. 23855500/ 23896600/ 30961742
The board u r getting supports dual channel.........so if u put 2 512MB sticks...the speed of each of the stick will be doubled...so u will get better performance out of the same amount of memory....
ASUS 945 PL is a good mobo....but i'm not too sure if it is very easily available.........
Sam :D Rulez :lol:
samrulez is offline
Old 13-07-2006, 02:29 PM   #10 (permalink)
1) You can't get serious gaming with a 5k graphic card. But maybe something to play the not very intensive games at low - med settings.
2)AFAIK Pentium D930 is for around 10k.
3) Amd 64 3000 Venice : 4500
or 3500 Venice : 5700
Asus A8N E : around 5k - 5.5k, maybe even almost 6k
2 X 512mb ddr 400 transcend (UCCC chips, if not available then Hynix D43 chips) : around 4k
250GB SATA II NCQ SEAGATE for 4200
Or wait for conroe, they will lead to price fall atleat, then may atleast, you might be able to core solo(celeron) in a low budget.
akshayt is offline
Old 13-07-2006, 05:45 PM   #11 (permalink)
I am not hardcore gamer but still don't want miss to play latest games also. I can compromise with the performance.
So I would like to go for XFX Geforce 7300GS particuler this model if available in Mumbai
http://www.newegg.com/Product/Produc...82E16814150128
The 7300GS is available at Prime ABGB at around 3650.00.
I guess this card mostly allow me to play all the latest games ofcourse not with very high frame rates.
I don't want to buy high end graphic card instead I would like to buy 2 GB ram. This would really improve the performance....what do you think ?
Now confused about mobo....I read at many places that Asus mother board gives more trouble installing XP & thier support is also not good. Also I am not planning for over clocking
So how about MSI or Gigabyte 945 mother board ?
Any one can suggest me any particuler model ?
birbal is offline
Old 13-07-2006, 05:55 PM   #12 (permalink)
What are you gonna do?
for office applications, 2gb over 1gb shouldnot be a much diff upto office 2003.
for vista : yes
for photoshop multitasking: yes, maybe
for office 2007 : not sure, but 1gb will be ok
Graphic card: don't get a 7300GS, I think it is TC. Consider atleast 7300GT which is around 4400. You will be able to play MOST(not all) current games at low settings at ok-ok or just playable frame rates.
All new games won't run acceptably on this card.
eg: GRAW won't be running ok, i ran it on 800*600 lowest and it was crap on a 6600GT which should be better than 7300GT non GDDR 3
if you can get then get 7300GT GDDR3
if you are a gamer then no point thinking below 7600GT/7900GT that too only for todays games.
2gb ram will be around 8-9k +-depending upon location.
akshayt is offline
Old 13-07-2006, 07:39 PM   #13 (permalink)
Following is the rates given to me by Prime ABGB PVt ltd
1)P4 930 Dual Core 3GHZ - 9600 ( You told me 6000 to 7000 !)
2)Inel Original 945 Motherboard- 6050
3) 2GB DDR2 Transcend Ram with three years warranty - 8100
4)nVidia 7300GT - 10,300 !!!!
5)VIP ....400 watt SMPS & Cabinet
6)Hitachi 250 GB SATA II - 4200
Do you know any other dealer where I can get at 7300GT around 4.5K ?
Thanks once again for your help buddy
birbal is offline
Old 13-07-2006, 09:38 PM   #14 (permalink)
samrulez's Avatar
Well.....actually u can get the 930 at around 8-9k at max.....
7300GT cannot be 10k.......coz 7600GT is 11K......
Actually 7300GT is under 5k on the net itself.....how can they charge 10k for the same.....how much memory did it have??
If cannot go for the 7300GT go for the 7300GS......that's under 5k...my firend recently bought 1.....
the
Sam :D Rulez :lol:
samrulez is offline
Old 14-07-2006, 09:09 AM   #15 (permalink)
get a 7600GS around 7k.
akshayt is offline
